Question about the TBI 305/350.
Results 1 to 3 of 3
5.0 and 5.7 Discussion, Question about the TBI 305/350. in Cadillac Engine Discussion; Why do the TBI 305 and 350's always crank over for an extended amount of time before they fire up? ...
    I~LUV~Caddys8792's Avatar
    I~LUV~Caddys8792 is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 Town Car Cartier & 2014 Accord LX MTX
    Dec 2004
    Roseville, MN.
    30
    34,087
    Why do the TBI 305 and 350's always crank over for an extended amount of time before they fire up? If you compare a L05 and LT1, the LT1 will fire up in a second, and you've gotta crank the TBI version over for a few seconds to get it to start up... Is it because the TBI versions will use much less fuel pressure?
    kevm14 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 Stealth Gray CTS-V, 08 Light Platinum SRX V8
    May 2008
    35
    1,354
    Re: Question about the TBI 305/350.
    Holy crap I just discovered this forum. Now I have two Cadillac Forums to check on.
    Anyway.
    The reason is pretty much because of the way the fuel system works. Unlike a carb you can't prime the manifold by simply pressing the gas pedal. The injectors, which sit over the throttle body, don't fire until the engine turns and it takes a few revolutions for the fuel to reach the cylinders, especially in a cold engine where the fuel is not going to atomize - it pools. However, I find TBI cars to be very quick firing when warm, easily as fast as an LT1, maybe a little faster. LT1s have port fuel injection and the fuel sprays right onto the back of the intake valves.
    On your next cold start try feeding a little bit of throttle (experiment on the amount). Mine starts faster this way but I actually prefer the extended cranking in the winter because it gives the oil pump a chance pressurize the engine (well, a head start) before it actually develops any torque and thus pressure on the bearings.
    Dec 2004
    Roseville, MN.
    30
    34,087
    Ah, sweet. Thanks for the info.
