5.0 skip... Out of luck?
Results 1 to 5 of 5
5.0 and 5.7 Discussion, 5.0 skip... Out of luck? in Cadillac Engine Discussion; Hello bretheren, Bought a 1991 Brougham D'Elegance from an old geyser who did nothing but drive and change the oil. ...
    Faded Crest's Avatar
    Faded Crest is offline Cadillac Owners Connoisseur
    Automobile(s): '66 SDV, '76 CDV, '89 BRM, '92 BRM, '98 Concours, '00 SDV
    Apr 2008
    North Carolina
    45
    3,222
    Hello bretheren,
    Bought a 1991 Brougham D'Elegance from an old geyser who did nothing but drive and change the oil. At 119,950 miles, the spark plugs were ORIGINAL, as were the AC Delco Cap/Rotor and numbered Packard Bell spark plug wires... Have a look at one of the spark plugs. Burned down from .035 to .055.
    http://imgs.inkfrog.com/pix/thejumpsuitman/100_8998.jpg
    The car had a little bit of a rough idle, so I naturally figured that a tune up would fix it, no go...
    So I drove 100 miles into the country with some Lucas Injector cleaner and 93 Octane in it, giving it a WOT whenever possible, no change, not even any black or brown coming out of the tailpipe.
    Then someone in the Brougham/RWD thread suggested it may be an EGR valve, so I replaced that, no change.
    Obviously, I am worried that I may be looking at a burnt valve. I didn't figure in that kind of work when I bought it, so I am looking for wisdom...
    Could it be anything else? Basically, it is a very slight, but consistent miss. There is a small exhaust leak toward the front, probably on top of the catalytic converter, or where it connects. The miss is only noticeable when just rolling to a stop. You can feel a pulsating flutter. But on the road, she screams! One of the strongest TBI 5.0's I have driven (I've had 3).
    If it is a burn valve, dare I drizzle some water down the throttlebody in an effort to break it up?
    Thoughts, anyone?
    Apr 2008
    North Carolina
    45
    3,222
    Re: 5.0 skip... Out of luck?
    In case the link doesn't work, here is a picture of that spark plug...
    Here's a picture of the car...
    Feb 2003
    california
    69
    6,626
    Go back to the basics. Run a compression test first. Then hook a vacuum gauge to it and report back what you get.
    Apr 2008
    North Carolina
    45
    3,222
    Problem solved... It was either the MAP sensor or a vaccuum line in that area. I replaced it, secured the hoses in the area, and now it runs PERFECT!
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    49
    7,531
    Sweet!!!
  8. Remove Advertisements
