1992 d'Elegance 5.7 liter coolant smell
Results 1 to 9 of 9
5.0 and 5.7 Discussion, 1992 d'Elegance 5.7 liter coolant smell in Cadillac Engine Discussion; So my brother just picked up a '92 Brougham d'Elegance with the 5.7 TBI motor. It has 130K miles. Yesterday ...
    96Fleetwood's Avatar
    96Fleetwood is offline Auto Enthusiast
    Automobile(s): 1992 Eldorado Touring
    Jul 2005
    Naples, FL
    37
    3,688
    It has 130K miles.
    Yesterday after a 50 mile drive from a job site, he smelled coolant when he got home. It does not leak anywhere.
    Do these motors have issues with the intake manifold gasket?
    Nothing leaking from the waterpump, hoses, or radiator.. any guesses?
    Thanks,
    Elias
    2015 Audi Q7 3.0T S-line - my DD
    2013 BMW Alpina B7 - wife's DD
    2002 Pontiac Trans AM WS6 Convertible Collectors Edition
    1992 Cadillac Eldorado Touring Coupe
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,533
    Re: 1992 d'Elegance 5.7 liter coolant smell
    A friend of mine had a similar situation on a 96 Burb 454. It was the weep hole on the water pump. It would leak and smell, but evaporate before it had enough to hit the ground. Got up underneath to finally find.
    My LT1 had a pin hole leak in the line from the coolant reservoir to the TB that sprayed a super fine spray that was very hard to see.
    Caps can do it also, look for it leaking.
    But my bet is on the water pump.... (sorry! I have seen it too much....)
    By the way, sharp new ride!!
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    Should not be manifold gasket unless someone mixed old green and the long life fluid that GM used a few years ago.
    Climb under car at night with a flashlight; easier to find.
    Jul 2005
    Naples, FL
    37
    3,688
    In 1992 they all came with Green coolant, that is all this car had.
    MadCaddie69's Avatar
    MadCaddie69 is offline Cadillac Owners Fanatic
    Automobile(s): 1990 Cadillac Brougham, My mom's 2001 Cadillac Deville DTS
    Aug 2007
    Jessup, MD
    113
    Mine did that within two weeks after my dad bought it. I'm thinking it might be the thermostat. Check that.
    Jul 2005
    Naples, FL
    37
    3,688
    It is the intake manifold for sure. Got the Felpro gaskets and going to try to do the job for him while I am in Virginia this week.
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,533
    Once you have the intake off, gasket match it will always guaranty designed/intended performance.
    If you can find them, the TorquePlus intake gaskets can help for carb cars, probably for TBI too by breaking up the fuel better before it hits the cyl port. Some think it doesn't work, yes, it does, my 455 responded nicely to it (make sure no sharp edged in the ports, else the screen will be cut and can be injested...) Cold weather and low rpm drivablility was noteably improved. All carb guys I highly recommend. TBI cars may not improve much, but likely will improve some. High rpm operation might suffer slightly, but not until over 5000 rpm. Which these cars likely never will see anyway. But cold and low rpm (and mpg) did improve.
    Jul 2005
    Naples, FL
    37
    3,688
    I did some research and most of the TBI truck guys recommended the Felpro gaskets. I used them on my '96 for the Valve Covers and they make a good product.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,492
    Intake gaskets are aproblem on them. Mine had that problem a few years ago and I think it has the felpro ones now too. TorquePlus now theres a name I havent heard in a while.
  12. Remove Advertisements
