90 Brougham w/ Olds 350
Results 1 to 2 of 2
5.0 and 5.7 Discussion, 90 Brougham w/ Olds 350 in Cadillac Engine Discussion; I am purchasing a Olds 350 from a guy in VA. The engine was in a 72 Cutlass. Comes with ...
    MadCaddie69's Avatar
    MadCaddie69 is offline Cadillac Owners Fanatic
    Automobile(s): 1990 Cadillac Brougham, My mom's 2001 Cadillac Deville DTS
    Aug 2007
    Jessup, MD
    113
    I am purchasing a Olds 350 from a guy in VA. The engine was in a 72 Cutlass. Comes with all the accessories I need and will fit my car and I getting it for a killer price. However, my greatest fear is mounting it with my 200R4 transmission, which was rebuilt a year and a half ago. The engine will produce up to 300 hp and my trans can handle up to 255 lbs of torque. Is there a trick I can do like replace the torque converter or should I get the TH350?
    joe_padavano is offline Cadillac Owners Member
    Automobile(s): 93 Allante
    Mar 2006
    Northern Virginia
    78
    Re: 90 Brougham w/ Olds 350
    The TH350 is a bolt-in. The trans crossmember will be moved forward and if the holes are not already drilled in the frame you may need to drill them. You'll need to adapt the kickdown cable, with is NOT the same as the throttle valve cable on the 200-4R.
