Results 1 to 6 of 6
Thread: Fan Clutch Dilemma
    davedbusman's Avatar
    davedbusman is offline Cadillac Owners Member
    Automobile(s): 1991 Brougham
    Dec 2006
    Syracuse, NY
    59
    17
    Fan Clutch Dilemma
    I have a 305 Chevy with TBI in the Brougham. The water pump turns CCW. Can I put a CW fan clutch in from an Olds 307?
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Re: Fan Clutch Dilemma
    IIRC, the fan clutch doesn't care which way it turns.
    GM has 2 fan clutches, large pattern to bolt to water pump (Ford, Pontiac and BBC use this size), and then Olds and Chevy use the smaller. Easy to spot.
    So you shouldn't have any problems.
    3141592654 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2007
    26
    Cool Re: Fan Clutch Dilemma
    Quote Originally Posted by N0DIH View Post
    There is a bastard fan clutch around that fits both the small and big block Chevies. It has slots instead of through holes for water-pump mounting.
    I bought one for a 1988 Cadillac Brougham (Olds 307) and it fit the Chevy 454 with no problem. Keeps the engine cool as a cucumber! I got it from Auto Zone.
    pi-
  5. #4
    Dec 2006
    Syracuse, NY
    59
    17
    Oh, gee.
    I already bought and replaced the clutch. I thought they were directional (one direction only). But I'll know next time. Thanks for the replies.
  6. #5
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    50
    7,531
    The fans are most definately directional.... Serpentine belt fans go one one most of the time, the V-belt cars go the same way the engine rotates.
  7. #6
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    I'd agree, the clutch doesn't know which way it is spinning but the fan blade is definitely the important component here.
    The clutch locks or unlocks based on temperature, doesn't worry about rotation.
  • You may not post replies
