high idle - 89 307
Results 1 to 5 of 5
5.0 and 5.7 Discussion, high idle - 89 307 in Cadillac Engine Discussion; i just replaced the intake manifold gasket and put new gaskets on the carb while it was off. i took ...
    gdorell is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2007
    89
    high idle - 89 307
    i just replaced the intake manifold gasket and put new gaskets on the carb while it was off. i took some pics of the vacuum hoses...so they look like they are ok. but now she has a really fast idle. without a tach its hard to gauge but if before it was idling at 600, now it must be about 900-1000 rpms.
    any ideas on how to narrow down my problems
    Motorboat is offline Cadillac Owners Member
    Feb 2007
    89
    Re: high idle - 89 307
    Sounds like a vacumm leak. Spray some starting fluid around the manifold and carb base while the engine is running, when the idle increases you have found the leak.
    RocketFast321's Avatar
    RocketFast321 is offline Cadillac Owners Fanatic
    Automobile(s): 1984 Buick Electra Estate Wagon aka Country Cadillac
    Jun 2003
    Montgomery,Al
    31
    395
    JTraik is offline Cadillac Owners Enthusiast
    Automobile(s): Too many...
    Mar 2004
    849
    I second the vacuum leak... You have to follow a specific pattern when installing the intake manifold, if not installed correctly it is likely that is the cuplrit.
    What kind of gaskets were installed?
    Jan 2007
    89
    one of the vacuum lines did have a slight crack in it. hate those pesking little things....
    im seriously considering putting in a tbi engine just to eliminate them
  8. Remove Advertisements
