Fuel pump life expectancy
Results 1 to 6 of 6
5.0 and 5.7 Discussion, Fuel pump life expectancy in Cadillac Engine Discussion; I try to stay ahead of replacements and breakdowns. Have managed 160000 on an 86 Brougham - Olds 307 V8. ...
    ChiTDI is offline Cadillac Owners Member
    Automobile(s): '86 Brougham
    Mar 2004
    54
    QuestionFuel pump life expectancy
    Do fuel pumps give symptoms before croaking?
    Engine runs well, carb rebuilt in '06, fresh tune etc. no current symptoms, just a thought.
    I think the fuel pump is original.
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Re: Fuel pump life expectancy
    Not really, they usually fail fairly suddenly in my experience. Lost a few that way. I eventually went to a electric pump to replace on my T/A, but the noise was excessive, so I went back. But the electric wasn't enough to pump fuel to my tame 455 and it would leanout at WOT around 1/4 mile into the run. The mechanical pump is a good piece, but being next to the engine caused my 455 fuel overheating, and the electric cured that.
    160K and factory pump, not a bad idea to replace to keep reliability up. My 76 Olds failed the factory pump around 80K miles, and promptly lunched the ignition module in the process (no idea the connection on that one). Years later the float decided not to anymore and flooded the engine, also lunching the ignition module again. Again, no clue why, it just did. These were early GM modules so maybe there was some quality issues there.
    No real symptoms except maybe hard starting or lean out when at lower rpm, then leading engine stall.
    Mar 2004
    54
    Thanks Nodih.
    I'll change it out before it gets me.
    boatman is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2007
    19
    if it is mechanical, it useually leaks when it goes. Electrics are all over the scale for reliability scale.
    JTraik is offline Cadillac Owners Enthusiast
    Automobile(s): Too many...
    Mar 2004
    western New York
    30
    856
    Quote Originally Posted by boatman View Post
    Possibly,but it takes 30 minutes to replace a mechanical... electrical... 3 hours.
    pimpin88's Avatar
    pimpin88 is offline Cadillac Owners Connoisseur
    Automobile(s): 01 STS, 92 Roadmaster, 01 SLS-sold, 88 Brougham-crushed
    Nov 2004
    northeast ohio
    28
    1,392
    It took my a while on my 307 brougham because of all the stuff you have to move out of the way to get to it. Not a hard job, just time consuming. Especially when you have to do it when it is 32 F and the car is outside.
  9. Remove Advertisements
