CD Player - am I too old? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Like Tree1Likes
2014+ Cadillac CTS General Discussion Discussion, CD Player - am I too old? in Cadillac CTS Third Generation Forum - 2014+; Originally Posted by jghiller I did a search on tools for migrating cds to usb and found Roxio listed. So ...
  1. #16
    pissedoffwookiee's Avatar
    pissedoffwookiee is offline Cadillac Owners Connoisseur
    Automobile(s): '16 CTS V-Sport Black/'16 CTS Luxury w/V-Sport Pkg White
    Mar 2013
    Carlsbad, CA
    4,218
    Re: CD Player - am I too old?
    Quote Originally Posted by jghiller View Post
    I did a search on tools for migrating cds to usb and found Roxio listed. So I used my Roxio and followed instructions for copying cd tracks to to usb.
    I was surprised to see the Roxio made wav files out of the tracks. WAV isnt supported for usb(as documented in CTS manuals). So then I fould instructions on YouTube and simply updated the option for o/p files ripped from pc to use and I just changed the format to mp3(which is supported).
    I used Windows Media Player.
    Would assume mp3 format superior to wav.
    no wav is superior to mp3
    when Roxio is set up that way is is just pulling off the raw musical data from the CD in its uncompressed form, one reason wav is not as widely used is because it creates files many, many time larger than an mp3, this is because wav is uncompressed and lossless
    mp3 on the other hand is a compression method and the form of compression is what is called lossy, meaning that you lose musical information creating them, how much you lose is determined by the settings used for that compression, 96k vs 320k for instance.
    there are some lossless compression methods flac is the big one here, but like wav not used a lot except for by audiophiles
    if you have the ability, set up roxio to do 320k variable bit rate, at high quality and you will have very sweet sounding mp3's doing this will get you 5 to 10 thousand songs on a 32gig usb drive instead of 10 to 20 thousand songs for a typical 128k fixed bit rate, medium quality settings that tend to be standard with a lot of mp3 creation software, this is a very good compromise of file size vs audio quality, is you have golden ears and need higher than i would suggest an iPod touch and record your CD's using iTunes and apples lossless format, that way you have no compatibility issues since the iPod handles that, and i said iPod touch on purpose the iPod classic seems to give CUE fits this is probably due to the spinning drive the classic has vs the flash memory the touch has
    WJrod likes this.
  2. #17
    jghiller's Avatar
    jghiller is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 XTS Premium
    Aug 2008
    SC/NJ
    1,431
    OK - but GM manual says wav files not listed as supported file types
  3. #18
    Mar 2013
    Carlsbad, CA
    4,218
    you wouldn't want to use wav anyway files too big
  5. #19
    Ardent is offline Cadillac Owners Member
    Automobile(s): 2014 Cadillac CTS Premium
    May 2014
    Tucson, Arizona
    9
    It took me a while to start using flash drives for music but now that I've swapped over from disks it is a lot more convenient. I didn't even both to see if the car had a CD player, I'm actually a fan of the CUE system.
  6. Remove Advertisements
