Results 1 to 3 of 3
Thread: SD & USB Ports
    cafpaf is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Jul 2008
    375
    SD & USB Ports
    I know that there is a USB port under the cover in the center stack and there is supposed to be another one or two in the armrest area as well as an SD slot. The ones in the armrest storage
    area are EXTREMELY difficult to even see let alone use. I tried to insert and SD card yesterday and was unable to do so. I think the you need a dental mirror just to see what you are trying to do. Does anyone have any tips to make this easier or even how to insert the SD card? As
    always, any help will certainly be appreciated. Thanks.
    Cool Rod's Avatar
    Cool Rod is offline Cadillac Owners Member
    Automobile(s): CTS V-Sport
    Dec 2013
    Miami
    41
    Re: SD & USB Ports
    cafpaf I thought the same thing, at least as far as the USB ports go. I haven't tried an SD card.
    The USB ports are hard to see and getting plugged in is awkward/tricky. The USB port in the CUE is a little easier to see but it's still awkward. And when you get plugged in the USB cord itself is usually so long that it eats up the storage space.
    You could just leave your USB cord in place and buy another one, but I found an 8 inch cord on Amazon that I use instead. I have an iPhone 5s that uses a USB to Lightning cable, and I bought the 8 inch cord and leave it plugged in the armrest USB port all the time. It's long enough to make plugging it into the iPhone very easy, but it doesn't need to be coiled up and eat up what precious little space there is there. If you use an iPhone it's a good alternative connector. It costs $10 and comes from China in the mail, so it takes about a week before it arrives. I tried a 4 inch cord first, but it was too short. If you're using a different device you might find a short cable that fits on Amazon.
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    If you don't want to put your iPhone in the armrest, then the only choice is to use the same short cord in the CUE, but I tend to forget my phone when I put it there.
    Otherwise your only choice is to leave a standard length cord in place and give up the space.
    Cheers
    Jul 2008
    375
    Re: SD & USB Ports
    I put a few albums onto a SD card and I finally got it inserted into the proper slot. I had to use a flashlight just to see what I was doing. However, now that I have done that, I am impressed at how well it works. That system is great. How much music can be put on a 2, 4,or 8 GB drive or SD card?
  • You may not post replies
