Just wondering what grade of gas people are using?
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
2014+ Cadillac CTS General Discussion Discussion, Just wondering what grade of gas people are using? in Cadillac CTS Third Generation Forum - 2014+; ...
    paulcts is offline Cadillac Owners Member
    Automobile(s): 2014 CTS
    Dec 2013
    68
    4
    QuestionJust wondering what grade of gas people are using?
    I recently took delivery of my new 2014 CTS with the 2.0 L Turbo. In reading the owner’s manual I notice it says this engine “can” use regular gas. It adds that if the driver notices “nocking” that an octane upgrade may be required. However, I notice that on the hinge of my gas cap door there is a sticker that says “premium gasoline recommended”. I have been using regular 87 octane gas and I have not noticed any “nocking”. So I am just wondering what kind of gas other folks are using and why?
    calif phil is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS
    Jan 2013
    Kansas
    513
    I would use premium.
    blankster is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS Premium AWD 3.6 DI (Sold)
    Sep 2009
    Chicago Area
    472
    You may get slightly decreased performance with regular due to the knock sensors. If you drive with a heavy foot use premium.
    hansumtoad is offline Cadillac Owners Member
    Aug 2013
    28
    Re: Just wondering what grade of gas people are using?
    93 when i can get it..... otherwise 92.
    Sir Nuke's Avatar
    Sir Nuke is offline Cadillac Owners Member
    Automobile(s): 2014 CTS Coupe, 08 STS
    Feb 2014
    Southeast Texas
    59
    78
    with your car......with out a doubt I would be using Premium.
    RJParks is offline Cadillac Owners Member
    Automobile(s): 2009 CTS4
    Apr 2013
    Omaha, NE.
    10
    I have the 3.6 DI AWD and have used everything from 85 with ethanol to 92 premium. Currently using a 87 non-ethanol and I'm very pleased with it. Better mileage and still responsive.
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    Considering the carbon deposit problems D/I has, if you planned on keeping the car for the average length of ownership (10 years or so) I wouldn't use anything except top-tier premium.
    ddawson is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS PREMIUM SEDAN 3.6 RWD
    Oct 2007
    1,019
    Another idea, would be to alternate every other fill up.
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by ddawson View Post
    I wouldn't do that. Alternating between 87/93 is only going force the ECU to constantly adjust ignition timing.
    If the car suggests 93, use 93, some top tier suppliers(like shell)use even more detergents in high grades.
    Non ethanol gas is great for fuel economy, but these days they usually contain very little detergents.
    Oct 2007
    1,019
    Quote Originally Posted by M5eater View Post
    Excellent point.
    ChevyRules is offline Cadillac Owners Member
    Automobile(s): 2014 Cadillac ATS Premium 3.6 AWD
    Mar 2014
    83
    The deposits though are on the valves, etc since they are no longer sprayed by the fuel when entering the cylinder. Regular vs Premium won't make much of a difference besides cleaning the fuel injector.
    But I echo everyone else's opinion and stick with premium fuel. The difference is ~$4 so it shouldn't be bank breaking..... And since it is a forced inducted engine, even more so to use premium.
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by ChevyRules View Post
    Internal EGR is why you want to use cleaner burning fuels. Most engines these days overlap the exhaust valve so that it is partially open on the intake cycle through clever cam phasing. Since no Engine has 100% VE (and thus why we need catalytic converters; to burn off unspent fuel), you're always going to have residual fuel in the combustion chamber which won't really wash the valves more than it will ensure a film of fuel is left on it so that deposits can't form. That means it's very important to select top tier fuels. That in combination with a quality synthetic(which finds it's way onto the valves in the form of vapor) is what's going to help keep deposits to a minimum. Good oils won't burn off and gum up on valves, lower quality oils will however; which has perpetuated the GL5 specification to ensure that even conventional oils these days are loaded with detergents and base stocks that are good for the high combustion temperatures of Direct Injected/ turbo engines.
    jghiller's Avatar
    jghiller is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 XTS Premium
    Aug 2008
    SC/NJ
    1,425
    Premium for Turbo or top of the line 3.6 engine. Regular Top Tier for standard 3.6L. Also use Fuel System Treatment Plus with oil change as recommended by GM.
  16. #14
    cts2014bknyc is offline Cadillac Owners Member
    Jul 2014
    10
    2.0 premium $45 in todays market for nyc prices. When the car was purchased in July it was $75.00
    the way it sounds with premium on startup especially for the price of my car not put regular!
    https://www.youtube.com/watch?v=xIXUk7TeaL8
  17. #15
    CTSVsport is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 CTS Vsport Premium
    Dec 2014
    Houston, TX
    45
    550
    All things being equal, you want to run the lowest octane the car can handle without engaging knock control. Too high an octane will result in more unburned fuel being exhausted due to its resistance to detonation and slower flame propagation.
    Direct injection should make the engine practically immune to knock, as there is no fuel in the cylinder until right before the spark plug fires.
    If you need more detergent, that's what Techron and Seafoam are for. I hadn't thought of the carbon deposit problem because of no fuel washing - Seafoam in the intake will definitely be more of a priority.
  18. Remove Advertisements
