Tracked tires replacement
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
2009-2015 Cadillac CTS-V Performance Mods Discussion, Tracked tires replacement in Cadillac CTS-V Series Forum - 2009-2015; How do you guys (and gals?) determine when to replace tires that have been tracked? I still have a good ...
    jzips's Avatar
    jzips is offline Cadillac Owners Fanatic
    Automobile(s): CTS V wagon
    Mar 2013
    131
    How do you guys (and gals?) determine when to replace tires that have been tracked? I still have a good amount of tread on most of my tires (the stock pilot sports that came with the car) after 4 track days, but there are parts of the tire that are worn below the recommended 4/32 tread thickness level (or even 2/32 for that matter)--specifically, on the front tires (a) the outer half of the approx. inch-wide center tread strip is largely worn off and (b) the very outside edges of the tire's treads are worn off. Not sure if I really need to replace the tires yet or not.
    Dr. Design is offline Banned
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    39
    3,406
    Re: Tracked tires replacement
    Sounds like those need to be replaced. Always respect the wear bars on the tires.
    cruiser68 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS-V A6 Sedan Modded :)
    May 2011
    Chicagoland
    711
    Street tires you can go by tread and I agree yours sound about done. Track tires are more likely to wear out by heat cycles and not necessarily tread. If you want to increase the fun factor try some R compound tires on the track.
    the blur's Avatar
    the blur is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Oct 2008
    NY
    1,014
    Pictures !!! and pump them up the next time you are on track.
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,735
    Yes, just get new/better ones.
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,997
    I agree, better to just replace them or save them for a burn out contest at a local car show.
    Heat cycles are the hardest on them, check for sidewall cracks or stress, and if the tires are at the wear marks at any spot, usually is best to replace. If there are cracks in the sidewall, I replace as well.
    jzips's Avatar
    Mar 2013
    131
    Sorry for the delayed response. Here's a photo of the one of tires.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    I, and others, have been trumpeting for a long time to pump the front air pressures up to mid 40s, hot. The edges won't wear if you do...
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,840
    Quote Originally Posted by thebigjimsho
    For track purposes or all the time?
    the blur's Avatar
    Oct 2008
    NY
    1,014
    I run 40's + PSI on the track. Because I am not destroying $800 worth of tires for a few fun laps. The tires hold very well at higher pressures.
    jzips's Avatar
    Mar 2013
    131
    I agree. I've started upping the psi after the initial outer wear and will keep doing that going forward As for the tires I've got (shown in the photo) would you guys run these tires on the track still or replace them now? My gut says they're good for another day or two.
    the blur's Avatar
    Oct 2008
    NY
    1,014
    Generally speaking, when I was doing 20 track days a season,... I ran tires until the cords were showing. "corded"
    baabootoo's Avatar
    May 2010
    Racine, WI
    3,735
    The problem that I had with higher pressures were that they'd climb so much, I'd get overpressure warnings - 50+ PSI. Secondly, they chunk those center ribs like his are. On most days now, I leave them at 32 for driving, then they heat to around 40-ish during track sessions. No uneven wear, and good traction. This is with the PSS's up front though as opposed to the PS's.
  16. #14
    Automobile(s): ZIP
    51,885
    Quote Originally Posted by jzips View Post
    You can drive them normally for awhile. I just wouldn't go crazy on a back road with them...
    Quote Originally Posted by Trapspeed View Post
    Just on track...
  17. #15
    Trapspeed's Avatar
    May 2011
    Central Florida
    2,840
    You can drive them normally for awhile. I just wouldn't go crazy on a back road with them... ---------- Just on track...
    Roger.
  18. Remove Advertisements
