Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Is anyone running a 91-92mm LS7 Throttle Body?
    Moparman4444 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V
    Jun 2010
    539
    I have read several threads about people trying the LS7 TB from a ZO6 Vette or other vehicles with mixed reviews.
    I thought that the LS7 TB was interchangeable with our 86mm stock TB. The reports are that the 102mm TB is too big for most engines but the LS7 is just about right increasing throttle response.
    Others have written that the throttle blade goes the wrong way and will not work but I have seen W4ME use them w/o problems.
    For about $130 Ebay special, its a cheap upgrade and better than porting a stock TB.
    What are your thoughts?
    Jun 2010
    539
    Re: Is anyone running a 91-92mm LS7 Throttle Body?
    seriously? 46 views and nobody is running a larger TB costing a few dollars?
    jb_bgg is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Black/Black V, Manual, Recaros, loaded
    Feb 2011
    Orange County, CA
    254
    I've got a ported LS7 on mine... no problems, better throttle response.
  5. #4
    Luna. is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Stealth Gray CTS-V, 2009 Black CTS-V
    Jun 2005
    CA
    3,571
    I'm a fan of the LS7 TB & believe there is minimal risk in going to it (it's a GM part afterall). This TB works fine on LSAs. I believe the TB that you are referring to (blade opens backwards) is the LS2 TB.
    The main issues I've experienced/read about are related to when people go to a 102 T/B, either NW or TPIS. I do NOT believe that the 102 is too big for "most engines" at all. They can work fine on a ~380" motor just fine, you just need to support it with the proper mods. When working well, they can really help in generating more hp, but I would also say that you probably want to have a very serious rwhp goal in order to justify going with it (i.e. >700rwhp), for the LS7 can support anything below that fairly easily.
  6. #5
    Jun 2010
    539
    thanks for the reply guys. Good to know the LS7 TB will work
  7. #6
    sykb47l is offline Cadillac Owners Member
    Automobile(s): CTS-V Coupe
    Jan 2013
    SATX
    71
    Love mine.
  8. #7
    SecretWeapon is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Sedan, M6, Silver/Ebony
    Oct 2010
    Spring, Texas
    457
    I had better results and driveability from porting the stock TB. Mine was done by a guy named Tony Mamo at AFR. I highly recommend him. Google search Tony Mamo Porting. I have done both and know what I am talking about on this. stick with the stock TB but have it ported by a pro.
  9. #8
    Titaniumseeker is offline Performance Enthusiast
    Automobile(s): 2009 CTS, 2009 CTS-V, 2012 CLS550
    Feb 2009
    Maryland
    479
    I'm running a LS7 TB that is ported. Noticeable better throttle response.
  10. #9
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,785
    So look into AFR for him to do the work? I found a lot of testimonials for him, but no contact info.
  11. #10
    Jun 2010
    539
    I did go with the larger 91mm TB and it seems to be working just fine in all respects. For $130, its a must do modification.
  12. #11
    jc09ctsv's Avatar
    jc09ctsv is offline Cadillac Owners Fanatic
    Automobile(s): 2014 cts Vsport
    Jul 2012
    orange county, ca
    36
    401
    I second that the throttle response change alone is worth the $$$
  13. #12
    baabootoo's Avatar
    May 2010
    Racine, WI
    3,785
    Quote Originally Posted by jc09ctsv View Post
    With the bigger one, or porting the stocker? I'm guessing the port work will cost somewhat more too, right?
  14. #13
    jc09ctsv's Avatar
    Jul 2012
    orange county, ca
    36
    401
    Quote Originally Posted by baabootoo
    I bought a ported and polished LS7 for like 145$ off eBay.
  15. #14
    baabootoo's Avatar
    May 2010
    Racine, WI
    3,785
    Wow, thanks.
  16. #15
    4DoorV is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-V Black
    Aug 2009
    83
    When going to a larger throttle body is tuning required, recommended, or not required?
  • You may not post replies
