Can you help me identify this differential cooling connector?
Results 1 to 8 of 8
2009-2015 Cadillac CTS-V Performance Mods Discussion, Can you help me identify this differential cooling connector? in Cadillac CTS-V Series Forum - 2009-2015; I picked up a differential cooler from D3 last week, and while the kit is fairly complete, the wiring is ...
    PeteK is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V Wagon, 1972 Eldorado Convertible
    Jan 2011
    Tehachapi, CA
    101
    I picked up a differential cooler from D3 last week, and while the kit is fairly complete, the wiring is still a rather DIY endeavor. Being a somewhat anal engineer and assuming that these cars are wired from the factory to support the unicorn-like OEM diff cooler, I went looking for the OEM connector to use as a source of power. After some digging, I think I found it under (over?) the muffler. It's a two-wire connector with what looks like appropriate gauge wire, with a cap installed in the plug from the factory.
    I wasn't able to find that connector on alldata, so I was hoping someone with a factory service manual (or first-hand experience) could help identify the part number so I can find the mating connector to use for the diff cooler kit. If anyone could help, I'd greatly appreciate it.
    Thanks!
    -Pete K
    SilverrV is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-V
    Apr 2013
    54
    Re: Can you help me identify this differential cooling connector?
    whatever you do , don't cut the yellow wire.
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    692
    Interesting. Since I'll be installing the same kit eventually too, I'll look at my FSM tonight and see what I can come up with. How do you like the kit otherwise?
    Alex
    flatrockguy's Avatar
    flatrockguy is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Raven V Sedan, M6, Graphite Rims, Yellow Brembos Sold
    Jan 2012
    Metro Detroit
    47
    342
    Here is the info your looking for, I think. Let me know if you need more..
    May 2013
    Naples, FL
    692
    Sweet. Let us know how it works out. This will be a future project for me.
    Jan 2011
    Tehachapi, CA
    101
    Quote Originally Posted by flatrockguy View Post
    Actually, I think that's the connector for the pump itself, which is part of the wiring harness that would be included with the OEM kit. I found the correct connector (attached). The service connector is a ridiculous $60 so I've found the Delphi OEM part and I'll put it together myself. I'll probably also use the same connectors for pump and fan connections (which is probably overkill, but hey why not).
    The only question I have now is where the relay location is and whether or not it's installed from the factory. Alldata lists it generically as 'Behind Left Rear strut Tower, but doesn't have anything further' I'm guessing it is already installed, since a relay isn't included with the OEM kit, but I'll probably just wait for the connector parts to arrive and test for voltage.
    Thanks!
    -PeteK
    Jan 2012
    Metro Detroit
    47
    342
    Here is where the manual states the relay is "Differential Cooler Pump Relay (KNR)
    In the luggage compartment, to the rear of the left strut tower 15 in (39 cm)"
    uptownvinc's Avatar
    uptownvinc is offline Cadillac Owners Member
    Automobile(s): CTV-V
    Jul 2013
    35
    47
    Quote Originally Posted by uptownvinc
    So with a oem diff cooler, it's as easy as plug and go?
    Damm I think my dealership didnt know about the hidden relay that they messed up(cut & connect) with wires related to parking brakes.
    My parking brakes arent working after installation.
    BTY, do both diff oil drain/fill bolts have sealings? I didnt see any when the new ones from the diff cooler were going in. and does anybody know whether drain bolts from The OEM cooler are magnetic ir not?
    I'm sure normal ones are.
  11. Remove Advertisements
