wideband wiring...need help!!
Results 1 to 5 of 5
Like Tree1Likes
  • 2 Post By beneseagal
2009-2015 Cadillac CTS-V Performance Mods Discussion, wideband wiring...need help!! in Cadillac CTS-V Series Forum - 2009-2015; For those of you that have a wideband...where did you wire into the power at? I'm assuming you only want ...
    thegraham77 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS V Coupe Thunder Gray ChromaFlair
    Jul 2012
    Iowa
    67
    For those of you that have a wideband...where did you wire into the power at? I'm assuming you only want power to it when the key is on. So where is the best place to hook into that?
    Thanks!
    beneseagal is offline Cadillac Owners Member
    May 2012
    18
    If it is low current and only draws a few miliamps just pop off the beauty cover on the drivers side dash there's a green wire that is ignition.
    Jul 2012
    Iowa
    67
    Re: wideband wiring...need help!!
    Directions say it draws less than 2 amps and power terminal should have 11 to28V DC attatched via a switch or relay when the engine is running.
    May 2012
    18
    So yes, you can just remove that cover between the door and driver side dash. Use a small panel tool to pull up the side towards you, there's three clips on it then slides towards you. Use a " T-Tap" connect on the green wire there you can also ground it there too! Good luck
    Stillborn and Stillborn like this.
    Jul 2012
    Iowa
    67
    Cool. Thanks!
  8. Remove Advertisements
