Amsoil Severe Gear for Rear Diff, still need Friction Modifier?
Results 1 to 13 of 13
2009-2015 Cadillac CTS-V Performance Mods Discussion, Amsoil Severe Gear for Rear Diff, still need Friction Modifier? in Cadillac CTS-V Series Forum - 2009-2015; I'm planning to swap out the rear diff fluid with Amsoil Severe Gear. I've seen a couple places that suggest ...
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    692
    I'm planning to swap out the rear diff fluid with Amsoil Severe Gear. I've seen a couple places that suggest some of these LSD oils already have friction modifiers and don't need any additional additive. When you guys swap diff oil, are you still adding some friction modifier per GM specs or just using the new oil alone?
    cruiser68 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS-V A6 Sedan Modded :)
    May 2011
    Chicagoland
    711
    Re: Amsoil Severe Gear for Rear Diff, still need Friction Modifier?
    I run Severe Gear and I add the limited slip additive.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    You MUST add modifier. Amsoil has said as such for our V2s. I ran without the first year with Amsoil and it howled. Sometime in 2010, Amsoil said to add. No more howl with it added...
  5. #4
    May 2013
    Naples, FL
    692
    Quote Originally Posted by thebigjimsho
    Sounds good. Modifier from GM and my Amsoil order arrive today. Love that I don't have to lift the back end to get at the diff. Plenty of room to slide under the car.
  6. #5
    Automobile(s): ZIP
    51,885
    Quote Originally Posted by spearfish25 View Post
    I have a driveway that slopes downward. I could back the V up onto ramps and have all the space this fatso ever needed...
  7. #6
    May 2013
    Naples, FL
    692
    I appreciate everyone's opinions but decided to ask Amsoil directly. Here is the reply:
    The Severe Gear line already has added friction modifier. Applications that require more than 4 oz of friction modifier may need additional product added if there is gear chatter.
    Since the manual only says to add 2.3oz of friction modifier if using GM fluids and draining with the drain plug, it would seem we don't need to add any modifier (unless you hear chatter afterwards, of course).
  8. #7
    sykb47l is offline Cadillac Owners Member
    Automobile(s): CTS-V Coupe
    Jan 2013
    SATX
    71
    Mine needed it.
  9. #8
    May 2013
    Naples, FL
    692
    Quote Originally Posted by sykb47l View Post
    Mine needed it.
    I may just put it in regardless. At least my clutch packs will last longer.
  10. #9
    ENVIOUS V is offline Cadillac Owners Member
    Automobile(s): 2012 Radiant Silver CTS -V, 1987 Buick Grand National
    Nov 2012
    SoCal
    51
  11. #10
    May 2013
    Naples, FL
    692
    I puss'd out and just put the 70ml of modifier in. Nice and quiet.
  12. #11
    miamictsv is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V
    Jul 2010
    165
    What is the part number for the modifier that you use? I may have to put some in mine. Thank you
  13. #12
    May 2013
    Naples, FL
    692
  14. #13
    OldRoadDawg's Avatar
    OldRoadDawg is offline Cadillac Owners Connoisseur
    Aug 2004
    NV
    1,903
    Quote Originally Posted by miamictsv View Post
    http://www.cadillacforums.com/forums...ml#post3060700
    Forum member 'C66 Racing' used to be a vendor for AMSOIL products and was who I purchased my products from last August. Not sure on his status currently, but you could PM him.
  15. Remove Advertisements
