Airaid CAI and tune on a stock CTS V coupe 6-sppeed results
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
2009-2015 Cadillac CTS-V Performance Mods Discussion, Airaid CAI and tune on a stock CTS V coupe 6-sppeed results in Cadillac CTS-V Series Forum - 2009-2015; Yesterday I was at RPM Motors in Santa Clarita, to get an AIRAID CAI and a tune on my 2012 ...
    Trainman SRT-10 is offline Cadillac Owners Member
    Automobile(s): 2012 CTS V Coupe, 6M
    Dec 2011
    Bakersfield, Ca.
    70
    73
    Yesterday I was at RPM Motors in Santa Clarita, to get an AIRAID CAI and a tune on my 2012 CTS V Coupe (6-speed manual). Really nice gains , Same dyno (Dynomite, SAE correction, similar to a Dynojet in calibration).
    Pure stock the rev limiter is at 6200 (or so) and I had them raise it slightly . Here are the results ( and we didn't put in a 160 Therm).
    RPM......Pure Stock RWHP.....Airaid RWHP......Gain.........Pure Stock RWTQ......Airaid RWTQ .....Gain
    2600.........212.9....................213.9....... ......+1.0................. 430.1..............432.0............+ 1.9
    3000.........253.4....................265.7....... .....+12.3................ 443.6.............. 465.2...........+21.6
    3500.........307.9....................321.7....... .....+13.8.................462.0..............482. 8............+20.8
    4000.........349.1....................372.6....... .....+23.5.................458.3..............489. 2............+30.9
    4500.........387.2....................416.7....... .....+29.5.................452.1..............486. 6............+34.5
    5000.........409.3....................453.1....... .....+43.8.................430.0..............475. 9............+45.9
    5500.........431.6....................477.2....... .....+45.6.................411.9..............455. 6............+43.7
    6000.........451.5....................500.3....... .....+48.8.................395.1..............437. 9............+42.8
    6200.........458.6....................507.2....... .....+48.6.................388.4..............429. 7............+41.3
    6500..........NA.......................515.3...... ................................NA................ ..416.3...................
    6600..........NA.......................515.6...... ................................NA................ ..410.3...................
    I'm really pleased. Pure stock peak numbers were 458.6 rwhp and 463.1 rwtq, and after AIRAID and Tune, 515.6 rwhp and 489.3 rwtq.
    AFR ratio was constant at 11.7 after tune and the boost was steady at 8.1 PSI across the board.
    Houdini's Avatar
    Houdini is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 CTS-V, 2010 CTS-V 6MT (Sold), 2007 CTS-V (Sold)
    Nov 2007
    St. Louis Metro
    1,404
    Re: Airaid CAI and tune on a stock CTS V coupe 6-sppeed results
    Nice results! I think stock should be closer to 9 PSI.... you might want to check that out.
    austin's Avatar
    austin is offline Cadillac Owners Connoisseur
    Automobile(s): ~2011 CTS-V Coupe & 2013 SRX~
    Apr 2005
    Boston, MA
    1,749
    Nice....
    Which Airaid are you using, what is the part number... Dry or Wet filter?
    Dec 2011
    Bakersfield, Ca.
    70
    73
    Quote Originally Posted by austin View Post
    Nice....
    Airaid 251-253, dry filter, plastic tube.
    Quote Originally Posted by Houdini View Post
    I checked the printout that had a numerical breakdown every 100 rpm and it did creep up to 9.1 at the end. I asked about that and they said it was probably due to a restriction in the stock exhaust and cats causing a rise in the cylinder pressure at a high volume moving through at higher rpm. Here's a breakdown at the higher rpm's: 5800=8.216, 5900=8.238, 6000=8.283, 6100=8.358, 6200=8.460, 6300=8.572, 6400=8.694, 6500=8.835, 6600= 8.995, 6700= 9.185.
    austin's Avatar
    Apr 2005
    Boston, MA
    1,749
    Quote Originally Posted by Trainman SRT-10
    I'm surprised your tuner raised the rev limit that high and dyno tested it at 6700rpm... I can see raising it an extra 200rpm, but to 6700rpm.. He must be thinking you have the same internals as a LS9. It's a nice run and ill give you that, but looking out for your own good I think it's way too risky to keep running a stock LSA at 6700rpm. On another note, great comparison of the Stock run vs Airaid run thanks alot for that.
    UBNZO6D is offline Cadillac Owners Member
    Automobile(s): None yet, but working on one - 2 ZO6's
    Nov 2009
    Chino Hills, CA.
    9
    Charlie raises to the customer request...It does not mean that Jerry revs it that high as I'm sure he shifts when it stops making good power...
    Greg
    Random84's Avatar
    Random84 is offline Cadillac Owners Enthusiast
    Automobile(s): Founder, OBWC
    Feb 2013
    Ohio
    562
    Quote Originally Posted by UBNZO6D View Post
    Greg
    Seems odd to dyno it that high unless the owner secifically requested a 6700+ limit - and then there's the whole "free advice" thing from an experienced tuner. OP describes his request as raising it as "slightly," so I agree it probably was specifically OP's request... it just seems like someone would say "how about 6400 RPM on stock springs - you know, just to not press your luck?"
    Dec 2011
    Bakersfield, Ca.
    70
    73
    Greg
    I only asked it be raised, I did not ask for a specific RPM limit. The car is still making power at 6600 rpm (peak power). At the latest test and tune I power shifted at 6500 (as best I can tell from the factory tach) each time still pulling and no loss of power. Once I get the launch down better my times will improve, as my MPH show good power and 11 second ET potential. Best run: DA 1250', 60' 2.055 (street tires), 1/8th mile 8.07 @ 93.16, 1/4 mile 12.240 @ 118.91 mph.
    mrkool is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, Harley VROD (Night Rod)
    Aug 2012
    261
    so if you don't get a tune do you still get these kind of numbers from just a CAI?
    Dec 2011
    Bakersfield, Ca.
    70
    73
    Probably not.
    austin's Avatar
    Apr 2005
    Boston, MA
    1,749
    Quote Originally Posted by mrkool
    http://youtu.be/NIwuW1ovkW4
    Gary Wells is offline Cadillac Owners Connoisseur
    Automobile(s): '09 CTS-V, 3K miles & '87 Turbo Buick, 29K miles
    May 2009
    Long Beach, Kali
    73
    3,435
    Quote Originally Posted by mrkool View Post
    Without the tune, try about 6-7 RWHP at best.
    Previously posted by user name "newcadman" on this forum on 07-31-2010
    P07-31-2010: 06:53 PM: newcadman: Re: All KPE CAI owners: As indicated I took my 2009 V -auto- V (7000 miles) to the same (dynojet) dyno where it was previously tested when it was bone stock…………… Three pulls were made with the now installed KPE cai. End result, the -engine- made 8 MORE rwhp on its best pull than it did on its previous best bone stock pull.
    austin's Avatar
    Apr 2005
    Boston, MA
    1,749
    I may have to take back my concerns..... I searched for a LSA Crate motor and in the details section it has 6600rpm as the max recommended rev limit. Everywhere I looked had 6600rpm as the max recommended limit. That is from GM's own LSA the spec sheet.
    http://www.chevroletperformance.com/...1708&engCat=ls
    http://www.jegs.com/p/Chevrolet-Perf...22868/10002/-1
  16. #14
    Nov 2009
    Chino Hills, CA.
    9
    I think he's referring to the ET & MPH...
  17. #15
    gaduser is offline Cadillac Owners Fanatic
    Automobile(s): 11 Black Diamond Edition CTS-V Coupe, 12 SRX, 17 Ridgeline
    Apr 2013
    Novelty, OH
    76
    130
    Nice improvement. So far, my 2011 Coupe is stock. However, I wonder if my exhaust is right.
    While looking over the underside of my V Coupe, I noticed that the cross section of the left exhaust pipe is quite oval, while the right is circular. That is in the area immediately behind the flange where the pipe becomes parallel to the ground. The height of the left pipe section is about 1.7 inches while the right is about 2.5 inches, the pipe diameter.
    That really seems odd for a high performance system. Since the two sides are so symmetrical, I would expect the pipe dimensions to be very similar at each point. Further, I expect that symmetry was actually chosen to provide good back pressure balance over the operating range.
    How does your's look? I would really appreciate hearing.
    Regards,
    gad
  18. Remove Advertisements
