Airaid CAI and tune on a stock CTS V coupe 6-sppeed results - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
2009-2015 Cadillac CTS-V Performance Mods Discussion, Airaid CAI and tune on a stock CTS V coupe 6-sppeed results in Cadillac CTS-V Series Forum - 2009-2015; WOW! Impressive!...
  1. #16
    Boosted2000si's Avatar
    Boosted2000si is offline Cadillac Owners Member
    Automobile(s): 10 CTSV
    Apr 2013
    Jacksonville, FL
    30
    Re: Airaid CAI and tune on a stock CTS V coupe 6-sppeed results
    WOW! Impressive!
  2. #17
    Random84's Avatar
    Random84 is offline Cadillac Owners Enthusiast
    Automobile(s): Founder, OBWC
    Feb 2013
    Ohio
    562
    Quote Originally Posted by austin View Post
    I may have to take back my concerns..... I searched for a LSA Crate motor and in the details section it has 6600rpm as the max recommended rev limit. Everywhere I looked had 6600rpm as the max recommended limit. That is from GM's own LSA the spec sheet.
    http://www.chevroletperformance.com/...1708&engCat=ls
    http://www.jegs.com/p/Chevrolet-Perf...22868/10002/-1
    Interesting thread on LS1Tech:
    http://ls1tech.com/forums/generation...sa-engine.html
    It would be nice to "know" the valvetrain is stable to 6600 - a spring replacement and tune would make this thing unbelievable.
    Note: one poster in the above thread mentioned the "marine version" of the LSA having a lower RPM limit due to warranty concerns and the amount of time a marine engine spends at full throttle/high RPM ranges - the link below shows a fuel cutoff of 5600 RPM, but I don't know if there are any camshaft changes. Anyway, "warranty" purposes might very well explain why some people ran run these engines higher without valve float... but it also means you need to be preventative on your valve spring maintenance!
    http://www.gmpowertrain.com/Librarie...rine.sflb.ashx
    I'm guessing the components are stable to 6600 RPM if Chevrolet performance is warrantying the motor for 36 months or 100K miles (!) as noted in the quoted links.
    I would be changing springs every 40K regardless.
  3. #18
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,840
    The pipe looked the same way on my '99 Camaro SS. That is, until the headers and off road Y-pipe.
