Damper removal
Results 1 to 6 of 6
2009-2015 Cadillac CTS-V Performance Mods Discussion, Damper removal in Cadillac CTS-V Series Forum - 2009-2015; Any tips on removing the damper to install larger one. Can't locate a puller that works....
    jimbo1320 is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V 2010
    Dec 2004
    Vermont
    70
    217
    Damper removal
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,997
    Re: Damper removal
    The oem gm one works well, or use a Chrysler one if you go to a part store that lets you borrow them. Like autozone.
    Dec 2004
    Vermont
    70
    217
    Re: Damper removal
    Thanks for the info. I got one from Advanced auto hoping it will work. I noticed the damper is embossed on the inner radius. That through me off when first examining the job. I had no Idea how I was going to pull it off. Still not that easy because of space limatations.
    wetcoast's Avatar
    wetcoast is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V Manual
    Jul 2010
    Langley, BC
    152
    Re: Damper removal
    The trick isn't pulling the old pulley off it's installing the new one. I tried redi-rod with washers stacked up and it didn't work. I ended up buying one from Colorado Speed (Hawk LS Series Install tool). Went on like butter.
    wait4me's Avatar
    Jan 2009
    warsaw indiana
    2,997
    Re: Damper removal
    We usually use the oem balancer installer to put them back on. It is basically a long threaded rod, with some washers, a hard spacer and two bolts. Makes it so simple.
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,753
    Re: Damper removal
    Quote Originally Posted by wait4me View Post
    I just used a long threaded rod too, which doubles as my tow hook! I didn't need a flexplate tool either, just a quick shot from an air ratchet loosened the bolt.
  9. Remove Advertisements
