brake hoses
Results 1 to 3 of 3
2009-2015 Cadillac CTS-V Performance Mods Discussion, brake hoses in Cadillac CTS-V Series Forum - 2009-2015; any hints on replacing front brake hoses ? I just took the tire off and took a quick look at ...
    the blur's Avatar
    the blur is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Oct 2008
    NY
    1,014
    brake hoses
    any hints on replacing front brake hoses ? I just took the tire off and took a quick look at it. Looks like the brake line wraps around, and you need to squeeze a line wrench in there.
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    Re: brake hoses
    a pic would be nice to help you out..
    I find if you turn the wheels the opposite direction to the side you are on it gives you the most amount of space to work in. I would start by disconnecting the caliper first, keepin a rag near by to catch all the fluid. you then remove the other side of the hose from the hard line and install the new hose in reverse order...connect to the caliper last and turn the wheel complete left and right to see if the hose gets caught on anything or is stretched...
    Have fun and dont forget to flush the old fluid out and replace with fresh fluid
    the blur's Avatar
    Oct 2008
    NY
    1,014
    Re: brake hoses
    I did the fronts yesterday. The 1st side took me longer. Then the 2nd side was a breeze. And they are certainly cheap enough. Less than $20 each from GM.
