D3 Chassis Bracing for CTS-V Sedan \ Wagon in stock now
Results 1 to 12 of 12
2009-2015 Cadillac CTS-V Performance Mods Discussion, D3 Chassis Bracing for CTS-V Sedan \ Wagon in stock now in Cadillac CTS-V Series Forum - 2009-2015; D3 Chassis Bracing D3 Chassis Bracing is designed to increase your vehicles torsional rigidity with D3 chassis bracing components. These ...
    Greg_D3's Avatar
    Greg_D3 is offline Cadillac Owners Fanatic
    Dec 2011
    104
    D3 Chassis Bracing
    D3 Chassis Bracing is designed to increase your vehicles torsional rigidity with D3 chassis bracing components. These undercarriage mounted chassis braces will greatly increase overall vehicle stiffness without decreasing ride quality. Having a stiff chassis will not only improve responsiveness and vehicle feel, it will also allow you to properly tune your suspension.
    Now that the vehicles chassis has been isolated it allows the energy to be transferred to the suspension components that are designed to handle such load. OEM manufacturers have found increasing the stiffness of the chassis to be one of the largest single performance gains in handling without increasing spring rates, spring stiffness, bushing diameter, or shock valving.
    These braces will install using OEM bolt hole mounting locations and not require any permanent modifications to the vehicle. Think about it as the performance gains of installing a roll cage in terms of stiffness without compromising interior cabin space and drivability/ride quality.
    Features:
    Constructed of 100% 4130 Chromoly Steel
    100% TIG Welded
    Made in the USA exclusively by D3
    Contact D3 For Pricing
    The D3 Group
    1787 E. 28th St.
    Signal Hill, CA 907555
    Tel: 562-595-8518 | Fax: 562-595-8519
    www.D3Groupinc.com
    Moparman4444 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V
    Jun 2010
    539
    Re: D3 Chassis Bracing for CTS-V Sedan \ Wagon in stock now
    Interesting. Who would have thought there was that much deflection which could have been designed out of the car to begin with.
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    8,867
    Will this work on a non-V wagon?
    Overclock This is offline Cadillac Owners Member
    Automobile(s): 2008 CTS AWD
    Jan 2013
    Ontario, Canada
    44
    Quote Originally Posted by tinman View Post
    Add non V sedan to that question.
    Very interesting!
    Random84's Avatar
    Random84 is offline Cadillac Owners Enthusiast
    Automobile(s): Founder, OBWC
    Feb 2013
    Ohio
    562
    If it's in stock, how many years to fabricate and ship?
    I keed, I keed.
    In all seriousness, what kind of weight penalty are we talking here? I expect my `13 Wagon to be a lightweight, nimble roadcourse machine and I want to stay as close to 3200 pounds as possible.
    Greg_D3's Avatar
    Dec 2011
    104
    Quote Originally Posted by Overclock This View Post
    Very interesting!
    We have a non V in at the moment as soon as we test fit the bracing on it i will let you know.
    Quote Originally Posted by Random84 View Post
    I keed, I keed.
    They are ready to be boxed up as we speak, both left and right side come in at about 25lbs combined
    tinman's Avatar
    Jul 2006
    8,867
    What are the made with and what is your price, please?
    Greg_D3's Avatar
    Dec 2011
    104
    They are made of Chromoly Steel, the price until the end of the month is $1199 shipped to the lower 48.
    tinman's Avatar
    Jul 2006
    8,867
    Thanks for your response.
    Da V-Man is offline Cadillac Owners Fanatic
    May 2012
    277
    Which track did you test these at and what was the lap time difference?
    Random84's Avatar
    Feb 2013
    Ohio
    562
    Quote Originally Posted by Greg_D3 View Post
    50lbs total?
    Not bad... this makes it much more interesting.
    Greg_D3's Avatar
    Dec 2011
    104
    Quote Originally Posted by Da V-Man View Post
    They were tested at just about every track last season of the Cadillac challenge. Times vary between cars and modifications prior to bracing but every driver reported better stability through corners as well as being able to apply power earlier when exiting a corner.
    50lbs total?
    They are about 25lbs together.
  15. Remove Advertisements
