Manual V launch technique
Results 1 to 5 of 5
2009-2015 Cadillac CTS-V Performance Mods Discussion, Manual V launch technique in Cadillac CTS-V Series Forum - 2009-2015; What are you guys slipping the clutch at 3500-4k rpm? Running pilot sports and I'm trying to find that sweet ...
    smashn808 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Radiant Silver CTS-V, 6MT
    Aug 2008
    Bay Area 707
    191
    What are you guys slipping the clutch at 3500-4k rpm? Running pilot sports and I'm trying to find that sweet spot.
    Chrispy's Avatar
    Chrispy is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS Luxury
    Apr 2012
    Ontario, Canada
    553
    Re: Manual V launch technique
    Depends entirely on track and air pressure.
    On stock PS tires I'd start at 22psi. Clean them off nicely (Drive around the waterbox if possible and then clean off the tires), bring revs to about 3500rpm roll off the gas and into the throttle smoothly and see what the track will hold. You probably wont be able to go full WOT until 2nd gear.
    I've gone 12.2 at 119mph on stock street tires and 11.8 at 120mph on DRs with the six spd manual in my 2012 Wagon. (Airaid was only mod)
    Random84's Avatar
    Random84 is offline Cadillac Owners Enthusiast
    Automobile(s): Founder, OBWC
    Feb 2013
    Ohio
    562
    Quote Originally Posted by Chris CTS V Wagon View Post
    Nice!
    Aug 2008
    Bay Area 707
    191
    Chris-
    Wow, those are some impressive numbers. What DR's are you running and what size? I've seen guys use the Z06 spyder fronts for drag rims. Do you know if NT05R's will fit on our stock rear rim by chance? I want something fairly sticky to play around with on the street too. Thanks for the info and Wagons rule all, too bad I cant afford one just yet.
    Chrispy's Avatar
    Apr 2012
    Ontario, Canada
    553
    Quote Originally Posted by Random84 View Post
    Nice!
    thanks!
    Quote Originally Posted by smashn808 View Post
    Chris-
    Thanks! I'm using replica 09+ Z06 fronts and 305 MT ET Drag radials. (18 inch diameter)
    Not sure on the NT05 for the street...I've heard from friends in high HP setups (1K RWHP Vipers etc) that they can be dangerous even in damp driving conditions. I plan to pick up 295 Michelin SS's when the stockers wear out. They hook better than stock and last longer to boot.
    Cheers,
    Chris
  8. Remove Advertisements
