Anyone running 19" TSW Nurburgring wheels?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Like Tree1Likes
2009-2015 Cadillac CTS-V Performance Mods Discussion, Anyone running 19" TSW Nurburgring wheels? in Cadillac CTS-V Series Forum - 2009-2015; I've spent the past couple of days searching threads... I've seen several people running 18's and 20's in the Nurburgring, ...
    BtwoG is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-V
    Sep 2008
    Atlanta
    35
    I've seen several people running 18's and 20's in the Nurburgring, but no one running 19s.
    It seems like the ticket is the 19x9.5 ET41mm up front and 19x10.5 ET65mm in the rear. And it looks like the rears will need a 6-8mm spacer.
    I would plan on running 275/35/19 PSS up front and 305/30/19 PSS in rear.
    Seems like the ultimate V wheel/tire combo.
    Anyone running this combination? Or even this fitment? Or have any comments?
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Don't worry about 18, 19 or 20. If the width and offset has been proven, it will work on 19" sizes...
    Marylandspeed's Avatar
    Marylandspeed is offline Cadillac Owners Connoisseur
    Automobile(s): None
    Apr 2010
    36
    1,320
    Re: Anyone running 19" TSW Nurburgring wheels?
    We have the 20" version on our Camaro shop car.
    www.marylandspeed.com Phone: 443-730-9428
    Call us for the best prices and service out there. Over 8 years supporting the GM performance market!
    2011 Thunder Gray CTS-V Coupe - Corsa Sport and CF Airaid Intake so far!
    Rule12b's Avatar
    Rule12b is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V Sedan
    Dec 2010
    Los Angeles
    567
    I ran the 19's as my track wheels. I only needed spacers because I ran a square setup so I ran some big tires up front.
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,733
    That should be one sticky dude on the track!
    Rule12b's Avatar
    Dec 2010
    Los Angeles
    567
    Quote Originally Posted by BtwoG View Post
    You can run 295's up front with a spacer. In the rear I ran the same size but you could probably go 305 no problem...Wait, I may have it backward and the spacers were needed in the rear. One way or another, you can go thick all the way around on the 19's. (though not as thick as I'm currently plotting. . .;-)
    Sep 2008
    Atlanta
    35
    Discount Tire is quoting 275/35/19 Pilot Super Sports for $318 each. Think I'll jump on a pair at that price.
    Random84's Avatar
    Random84 is offline Cadillac Owners Enthusiast
    Automobile(s): Founder, OBWC
    Feb 2013
    Ohio
    562
    If you're ordering aftermarket wheels, why use a spacer (versus ordering the correct offset from the get-go)? Is that just not available, thus making "custom spec'd" wheels necessary... and very, very expensive?
    (I'm looking at a CTS-V as a DD and my first mod would be wider wheels/tires)
    Sep 2008
    Atlanta
    35
    Correct. Offsets are limited in most aftermarket wheels. GM vehicles use a more positive offset than many other vehicles, making the choices more limited.
    Below is a list that I compiled. To run a 10.5 in the rear seems to require something less than +59 or so.
    19x9 +51 Stock front
    19x9.5 +56 Stock rear
    18x9.5 +40 TSW Nurburgring
    18x10.5 +58? Stock C5 Z06 + 5mm spacer
    19x10 +40 Stock Coupe rear
    19x9.5 +41 TSW Nurburgring
    19x10.5 +27 TSW Nurburgring
    19x10.5 +65 TSW Nurburgring
    18x9.5 +56 C5 Z06 replica
    19x10 +56 C6 ZR1 replica
    thebigjimsho and thebigjimsho like this.
    Trionalaw is offline Cadillac Owners Fanatic
    Automobile(s): none
    Dec 2011
    64
    249
    I just checked today at discount tire.they now are quoting them at $356 per tire.
    Sep 2008
    Atlanta
    35
    The in store price was better than the online price.
    Automobile(s): ZIP
    51,885
    I can personally vouch for the first 4 on your list...
    rgp6373 is offline Cadillac Owners Member
    Automobile(s): 2009 cts-v
    Feb 2009
    43
    87
    i am thinking of running this same setup. just trying to figure out offset spacers and such . so if i run the 10x9.5 with the 41mm offset i dont need a spacer? but the 19x10.5 with 65mm i do need a 6-8mm ? would the 10mm from d3 be to much? where would i get 8mm spacers?
  16. #14
    Havasusteve's Avatar
    Havasusteve is offline Cadillac Owners Fanatic
    Automobile(s): 12 TG Sedan; SOLD
    Jun 2009
    Upland, CA
    56
    303
    How about running a 19x9.5 square setup? That is what I would like to do. I run 295.30.19 on my 10.5 rears and 9.5 fronts.
  17. #15
    Low_ET's Avatar
    Low_ET is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS-V, Thunder Gray, Auto
    Mar 2009
    East Central Florida
    221
    Quote Originally Posted by Havasusteve View Post
    I am about to buy a set of 19x9.5 wheels. The optimal offset in a 9.5-inch wheel is 45 mm for the front. So, if you want a square setup (like I do), then 19x9.5 - 45 mm is the best bet.
    TSW does not list that offset, but their other brand/label, "Beyern Wheels", does. Beyern has the Nurburgring wheel listed as the "Beyern Spartan" with the better offset. Beyern also sells a wheel called the "Bavaria" with the optimal offset. Those are both made using TSW's Rotary Forge method to get a strong, lightweight wheel.
  18. Remove Advertisements
