Heat exchanger?
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Like Tree3Likes
2009-2015 Cadillac CTS-V Performance Mods Discussion, Heat exchanger? in Cadillac CTS-V Series Forum - 2009-2015; What heat heat exchanger should I get? My mods are 2.5 upper pulley airaid cai, ls7 tb, and diablo trinity ...
    jc09ctsv's Avatar
    jc09ctsv is offline Cadillac Owners Fanatic
    Automobile(s): 2014 cts Vsport
    Jul 2012
    orange county, ca
    36
    401
    Heat exchanger?
    What heat heat exchanger should I get? My mods are 2.5 upper pulley airaid cai, ls7 tb, and diablo trinity tune.
    larry arizona is offline Cadillac Owners Connoisseur
    Automobile(s): 10 V 4DR,6M,Blk,2.55,airaid,160t,W4M HX & tune Eibachs
    Feb 2012
    Metro Detroit
    45
    1,347
    Re: Heat exchanger?
    any of them will do. They are all better than stock.
    jc09ctsv's Avatar
    Jul 2012
    orange county, ca
    36
    401
    Quote Originally Posted by larry arizona
    Does it replace the stock one? Iris it an added HX?
    Stillborn's Avatar
    Stillborn is offline Cadillac Owners Enthusiast
    Automobile(s): 09 DW 4DR,AT,Recaros,metco 2.4,RX c-can,AEM-A/F, 634hp,642tq
    May 2011
    tri-state
    47
    776
    Re: Heat exchanger?
    to be honest one isn't needed for street driving. if you track it then one wouldn't hurt.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Still not needed. Drag strip, maybe...
    Most aftermarket are not as efficient as stock...
    Feb 2012
    Metro Detroit
    45
    1,347
    Re: Heat exchanger?
    Some replace the stock one, Some are added to the stock one,
    With any boost increase I disagree that the stock one (its tiny) is sufficient for any sustained application of boost. Put a gage to IAT2 and a couple pulls on the street and you are easily at 140F (where ECM starts pulling timing) and it takes a long time to settle down. With added HX it takes much longer to approach 140F and comes back down very quickly.
    Personally I run a added W4M HX and it works great with the stock one. I also run 90/10 water glycol mix with NEO keep cool water wetter in the intercooler loop. IAT's are very manageable even in 90F+ weather. $400 is cheap insurance and performance
    Havasusteve and Havasusteve like this.
    Automobile(s): ZIP
    51,885
    I'm running 10.8 lbs max boost and 630hp and have tracked at VIR in 95 degree heat with consistent power. Stock exchanger...
    Feb 2012
    Metro Detroit
    45
    1,347
    Re: Heat exchanger?
    less heat is always better, you may not notice KR on a road course as you are rarely WOT for long but adde boost= more heat= less power= why did you increase boost in the first place if you are giving 5hp back per degree of KR. $400 is a worthy investment in my opinion.
    Umrswimr's Avatar
    Umrswimr is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Mar 2010
    420
    Re: Heat exchanger?
    Quote Originally Posted by larry arizona View Post
    Which HX is $400? Katech is twice that.
    http://store.katechengines.com/cts-v...nger-p267.aspx
    Feb 2012
    Metro Detroit
    45
    1,347
    Re: Heat exchanger?
    W4M HX is $400
    Mikes2009V's Avatar
    Mikes2009V is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTSV
    Feb 2012
    Cinnaminson, NJ
    39
    121
    I also have the W4M heat exchanger. I bought it from him a couple weeks ago. Fairly easy install and nice quality piece. Just gets installed in the lower grill and is in addition to the stock unit.
    jc09ctsv's Avatar
    Jul 2012
    orange county, ca
    36
    401
    Re: Heat exchanger?
    Quote Originally Posted by Mikes2009V View Post
    Do you notice a big difference in your IAT's? Does it help lower engine temp as well??
    Feb 2012
    Metro Detroit
    45
    1,347
    Re: Heat exchanger?
    yes the W4M makes a big difference in IAT2 and helps IAT2 recovery time after some heat soaking. Any HX will work better with 90/10 water glycol mix and then use a good water wetter (still need to increase gycol in winter for freezing concerns).
    HX will not improve engine coolant temps. Intercooler loop is a seperate cooling loop. About the only thing you can do to reduce engine temps is go to a 160F thermostat AND get your fans tuned to turn on sooner and stay on longer. A 160F stat on its own will do nothing.
  16. #14
    Tampa2Dubai is offline Cadillac Owners Member
    Automobile(s): '12 CTS-V Sedan
    Feb 2012
    Dubai
    53
    Re: Heat exchanger?
    Im still not sold on the aftermarket HX idea. Blocking the front grill with an aluminum brick doesn't seem the best route to go, especially in warm climates.
  17. #15
    Feb 2012
    Metro Detroit
    45
    1,347
    Re: Heat exchanger?
    Agree T2D, For your climate it is not a great idea. But here in the states we dont have that concern of being so hot that blocking most of the lower grill can cause issues with the actual radiator flow. I can't think of anywhere in the US that gets as hot as Dubai.
    You would be a great candidate for a super chiller type set-up.
    LA
  18. Remove Advertisements
