HX Coolant Tank Options? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Like Tree3Likes
2009-2015 Cadillac CTS-V Performance Mods Discussion, HX Coolant Tank Options? in Cadillac CTS-V Series Forum - 2009-2015; Originally Posted by FFBOS Steve. Were you leaking out of the fittings? I was leaking out of the bottom fitting. ...
  1. #16
    Havasusteve's Avatar
    Havasusteve is offline Cadillac Owners Fanatic
    Automobile(s): 12 TG Sedan; SOLD
    Jun 2009
    Upland, CA
    56
    303
    Re: HX Coolant Tank Options?
    Quote Originally Posted by FFBOS View Post
    I was leaking out of the bottom fitting. No matter how much tape/goop, I still seemed to leak. Same with the plastic cap. If I try and fill the reservoir up, it sloshs and some comes out.
    By Putting heavy silicone, changing out to brass fittings and pipe thread, I no longer have any issues. That is just my personal experience
  2. #17
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,819
    Still make the RX can, but I have to say the one your reffering to has larger capacity than ours and a better fill cover setup.
    Were using brass fittings now also.
  3. #18
    FFBOS is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Black Raven CTS-V (613rwhp/606rwtq) 10.7@125
    Jan 2011
    NW Burbs of Chicago
    31
    269
    I have a trickle out my bottom one. It was tight with tape on there, but after running it for over a month its pretty loose.
    I'm going to drain the tank and retape/retighten that bottom one. If that doesn't work I'll go brass
  4. #19
    Reeper is offline Cadillac Owners Member
    Automobile(s): 2010 CTSV 2007 Escalade ESV
    Feb 2012
    Pembroke Pines, Fl.
    47
    75
    try a lil permatex thread sealer, might help?
  5. #20
    Guard dog's Avatar
    Guard dog is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS V, 707rwhp blower, 868rwhp spray, 9.99@139.98
    Aug 2012
    Outside Memphis
    116
    I installed mine with brass fittings, Teflon tape and thread sealer and it seems to stay dry. I've run a drain line to the lower fascia in front of the passenger front wheel to allow drainage for ice melting at the track. I used an existing hole and 5/16 fuel line and put a couple zip ties on the end so it wouldn't pull back through the hole. I plan to install a 1/8 npt bleed port in the top of the lid to allow overflow drainage and CO2 exhaust when using dry ice. I hope to get the whole HX assembly below 60 degrees in 100 degree heat.
    Havasusteve and Havasusteve like this.
  6. #21
    Jun 2009
    Upland, CA
    56
    303
    Quote Originally Posted by Guard dog View Post
    I have always seemed to be fine when using teflon tape, but this bugger on the bottom wont seal! Next time I will use plumming dope I guess. PITA to drain and remove. Im already tired of it....
  7. #22
    Guard dog's Avatar
    Aug 2012
    Outside Memphis
    116
    Steve, I just finished my vent installation. When I get the chance to test everything at the track, I'll post some pics "elsewhere". The reason I used Teflon tape and thread sealer was this thread warning about the bottom leaks, so thank you!
  8. #23
    kj217's Avatar
    kj217 is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-V
    Sep 2012
    99
    I'm happy with the plastic pieces as well.
    I have the car tuned now to run the HX pump with the key on so I can use that option to see if it helps at the track while sitting.
    a tune is required to do so?
  9. Remove Advertisements
