GM 2 piece front rotors 09-12 CTS-V - Page 8
Page 8 of 8 FirstFirst 12345678
Results 106 to 111 of 111
Like Tree27Likes
2009-2015 Cadillac CTS-V Performance Mods Discussion, GM 2 piece front rotors 09-12 CTS-V in Cadillac CTS-V Series Forum - 2009-2015; Originally Posted by soon to V I put the 15mm spacers in front and the 11mm in back. It seems ...
  1. #106
    the blur's Avatar
    the blur is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Oct 2008
    NY
    1,019
    Re: GM 2 piece front rotors 09-12 CTS-V
    Quote Originally Posted by soon to V View Post
    I put the 15mm spacers in front and the 11mm in back. It seems perfect in look and no interference so far anywhere. So: I highly recommend it all.
    I run the coupe rear wheels, up front, no spacer. It's a 40mm offset. Your setup is probably 41mm offset including the spacer, if your running sedan rears up front.
  2. #107
    soon to V's Avatar
    soon to V is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V
    Mar 2004
    Ohio
    184
    Quote Originally Posted by the blur View Post
    sedan fronts up front.
  3. #108
    the blur's Avatar
    Oct 2008
    NY
    1,019
    Try the coupe wheels up front. you get 10", with the same offset your running now. No spacer.
  5. #109
    KongZTT M45 is offline Cadillac Owners Member
    Aug 2013
    Does anyone have the full dimensions of these rotors?
    Overall diameter:
    Thickness:
    Height:
    Rotor offset from hub/wheel mounting face to face of outboard friction surface?
    Thank you very much!
  6. #110
    soon to V's Avatar
    Mar 2004
    Ohio
    184
    Quote Originally Posted by KongZTT M45 View Post
    Overall diameter: 14 & 5/8ths inch
    Thickness: 1 & 3/8ths inch
    Height: 2" not counting the 2 piece bolt heads. They add another 1/4".
    Rotor offset from hub/wheel mounting face to face of outboard friction surface? :5/8ths of an inch NEGATIVE DROP. So the Outer friction surface of the rotor is 5/8ths more inward than the rotors outside mounting surface where the wheel mounts too. The thickness of the rotor mounting section is 3/8ths.
    Sorry for delay. Just doing a full 4 wheel brake job tonight so I measured my two piece front rotors up for you. These are not caliper measurements, but they are accurate tape measure measurements (in inches). See Bold above. Hope this helps.
    GMX322V S/C likes this.
  7. #111
    citori01 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 cts-v
    Jun 2010
    Sarasota
    47
    176
    I got mine under warranty.
  8. Remove Advertisements
