CTS-V2 Fuel System Warning - Important!
Page 1 of 8 12345678 LastLast
Results 1 to 15 of 116
2009-2015 Cadillac CTS-V Performance Mods Discussion, CTS-V2 Fuel System Warning - Important! in Cadillac CTS-V Series Forum - 2009-2015; Edit 12/12/2010 at 7:25 PM CST: If you're just now reading this, or coming back to revisit some of my ...
    RWTD's Avatar
    RWTD is offline Cadillac Owners Member
    Jan 2009
    Mobile, AL & Denver, CO
    42
    38
    ExclamationCTS-V2 Fuel System Warning - Important!
    Edit 12/12/2010 at 7:25 PM CST: If you're just now reading this, or coming back to revisit some of my information, the answer has been found to the pressure limitation of the factory CTS-V2 fuel system. Please see my post within this thread located here (it's the 1st post of page 2 of this thread):
    http://www.cadillacforums.com/forums...ml#post2440763
    Most of you are aware, but for those who aren't, the '09+ CTS-V, like the '09+ ZR1, and many of the E85 GM trucks, incorporates an electronically controlled fuel system, consisting of variable voltage pumps, FPCM (fuel pump control module), and an LFPS (liquid fuel pressure sensor). Fords from basically '99-'10 use a very similar system (variable output Walbro pumps made for Ford, an FPDM, aka fuel pump driver module, and an FRPS, aka fuel rail pressure sensor). On these types of vehicles, one can modify the fuel pressure within the PCM, which is a huge plus for those attempting to increase injector capability, especially factory injector.
    From the factory, the CTS-V and ZR1 utilize an injector that flows approx. 52.x psi at 4-bar (58.x psi). With increased DeltaP, these injectors are capable of 650-700+ rwhp Actual (Uncorrected), as I have regularly obtained such on modded C6 ZR1s.
    Here is a screenshot of the injector flow rate table from the CTS-V2:
    The factory CTS-V2 pumps are rated at 190lph each at 4-bar, and here are screenshots of the various fuel pressures that the CTS-V and ZR1 will see from the factory:
    CTS-V2
    ZR1
    Anyway, to my subject of this thread:
    Note: Power numbers that I quote are Actual (Uncorrected) at sea level. I do NOT quote SAE numbers for component range capabilities, especially the fuel system. If you live at higher elevations, such as Colorado, you will more than likely never run into the issues I'm about to mention below, since you'll have approx. an 18 to 22% lower overall power output than someone at sea level.
    I just returned from another week long tuning event in Puerto Rico (I was last there in 2005). I had the pleasure of working again with multiple friends of mine, namely Christian from Auto X Dyno, and also Dennis and his CTS-V2 (auto), C6 Z06, and '03 Cobra. Like many other CTS-V2s I have tuned, Christian and I also found that Dennis's factory factory fuel system is basically done at anything much over 525 to 550+ rwhp/rwtq Actual on the A6 (550 to 575+ on the M6). FYI, these power #s represent approx. 13 to 15 psi of boost at sea level, and these quoted numbers can vary by +/- 25 rwhp, depending on a variety of factors. Also, the reason the A6 hits the limit at lower power numbers is due to the increased drivetrain loss.
    Here is a datalog of my friend's CTS-V2 showing the various pids logged, including fuel pressure (I cut out some of them that weren't as pertinent, to decrease file size):
    http://www.rwtd.com/tuning/gm/fuelin...yno8_test6.csv
    (right click, save as)
    Note: The Commanded air/fuel at WOT is 11.6, which was also Actual as measured by Christian's lab-grade wideband (do NOT trust low-cost aftermarket widebands, unless it's at least an NGK AFX with NTK sensor). Part of this is due to the fact that most all gas is now E10 (contains 10% ethanol). Generally, on boosted vehicles one shoots for an AFR of not any leaner than 12.0 for 100% pure gas (stoich of approx. 14.7), and not any leaner than 11.6 on E10 (stoich is approx. 14.1). This isn't a rule that always apply to every vehicle, depending on a variety of factors (such as compression). With that being said, the richer the fuel mixture, the more of both fuel pump and fuel injector is used.
    At 6000 rpms in the datalog (frame 190), you will notice the Commanded (aka Requested) fuel pressure is 65.3 psi, which is exactly what it is Requested within the tune (see screenshot I gave above earlier). Then you will notice the "Injector Delta Pressure" is 52.7 psi. Measured MAP (manifold absolute pressure) here is also 195 kPa, which is approx. 13.x psi of boost (see calculator here, then one must subtract atmosphere pressure, which was approx. 14.x the day of the dyno tuning). Commanded Pressure minus boost = Injector Delta Pressure, therefore 65.3 - 13.6 = 51.7 psi, so these calculations are inline with the measured data.
    Note: A fellow tuner (Flash Me) once wrote a very easy to understand explanation of fuel pressure versus boost, so I figured I'd quote that for you here:
    I find it easiest, when thinking about boost vs fuel pressure, to imagine a fight going on. Fuel rail pressure is on one side of the fuel injector, trying to push fuel thru it at around 39 psi on most Fords. In an NA car, that's the only fighter, so 39 psi makes it thru the injector.
    In a boosted car, you have boost psi trying to push that fuel back up thru the injector, say at 10 psi. So one side of the injector has 39 psi, and the other has 10 psi. In this case, the net pressure going into the motor would be 29 psi. This net pressure is called pressure drop across injector.
    Note: generally, older cars have fuel pressure regulators that are boost referenced, and raise the fuel pressure from 39 to 49, so the 49 psi vs the 10 psi of boost creates the net pressure drop across injector of 39 psi again. As long as fuel pressure is raised 1:1 with boost pressure, the net pressure drop across the injector remains the same... 20 lbs of boost, 59 psi would be required.
    Now you know how boost requires an increase of fuel pressure = to boost psi, in order to maintain the 39 psi. This pressure maintainence means the injector flow rate remains constant... x lbs of fuel at 39 psi, or whatever the injector is rated at, so long as fuel pressure is = to that injector rating.
    Now, at the same frame (190) you will see that the injectors hit 100% DC (duty cycle) by 6000 rpms (see logged IPW, aka injector pulsewidth - use calculator here). At this point, AFR starts to creep up leaner, thus causing some slight knock at approx. 6200 rpms (until we can rectify this issue, I had to limit Dennis's shift points to 6000 rpms for the time being). So I attempted another test, which was to raise the Commanded fuel pressure to match that of a ZR1. If the output of the pumps were strong enough, and there was no maximum deadset limit of the fuel pressure (such as a regulator built into the pump assembly, like on the 2010+ Camaros), we should be able to increase injector output, thus preventing the injectors from hitting 100% DC. Here's that test:
    http://www.rwtd.com/tuning/gm/fuelin...yno2_test2.csv
    If you go to frame 174, you will notice that the Requested fuel pressure changes from 72.5 to 87 psi. However, take a look at the Inj Delta Pressure, it's only 54.5 psi. Notice MAP is at 194 kPa, aka 13.x psi of boost? 87 - 13.x = 73.x, not 54.5. This tells me we have either a fuel pump limit issue, or a fuel pressure deadset limitation from the pumps (potential mechanical regulator just off the pumps?). If the CTS-V2 does NOT have a max pressure limit, like the Camaros (more on that at the end of this post), due to a mechanical regulator, then the issue is clearly that the factory fuel pumps are NOT enough once the aforementioned power levels I stated are reached. My assumption, at this point, is it's the pumps, but until someone can show me a picture of the pump assembly proving that there is not a mechanical regulator off of them, I'll stand by this.
    In regards to the ZR1, the fuel system can definitely reach 87 psi and maintain that. Here is a log from my friend's ZR1 proving such:
    http://www.rwtd.com/tuning/gm/fuelin...no17_test5.csv
    Go to frame 230, and you will notice that the Requested fuel pressure is 87 psi, and Inj Delta Pressure is 71.2 psi, and MAP is 193 (approx. 13.x psi of boost).
    These fueling issues on the CTS-V2 are really nothing new, as others have ran into this problem as well. However, I'm writing this thread because I feel that the issue is not being discussed enough, nor properly, by the community here, nor many of the tuners, as most are blind to the issue at hand (yes, believe it or not). Furthermore, it seems that too many are installing parts/tunes, and then hotrodding their cars without knowing the potential consequences that may face them (i.e. blown engines). I can assure you that 99% of you are guilty of this (can you state you've datalogged your fuel pressures and AFR?). Another thread others have come across the fueling issue in is located here:
    http://www.cadillacforums.com/forums...striction.html
    I have not measured the output voltage from the Caddy FPCM, but if it is anything like the the 2010+ Camaros, the FPCM limits the output voltage to a max of 12.8v (see here). Currently, we tuners are not able to modify the FPCM max voltage output/limit, since the current crop of tuning software manufacturers do not access the FPCM control module. If we were able to, this would allow us to increase the output limits from the FPCM, thus potentially being able to install a BAP *before* the FPCM (see below). This is all in theory, however.
    Basically, you have two options at this point:
    1 (easiest): Kenne Bell Boost-a-Pump or a Magnavolt (what Whipple uses on their Camaro kits). If you install this, it is imperative that you install this post-FPCM, otherwise you'll run into issues with the FPCM controlling the voltage going into it, and preventing any additional voltage going out. This is contrary to a Ford with a similar system, in that you should always install a BAP pre-FPDM, as Ford's FPDM (fuel pump driver module) will allow for the additional voltage into it and out, as needed. LPE sells a complete kit that includes a KB BAP here, however you may be able to buy a KB BAP and build your own wiring harness for cheaper. Kenne Bell (BAP) and Whipple (uses Magnavolt) install their systems post-FPCM.
    2: Install pumps with the ability to flow more lph at the same voltage output, such as the ZR1 pump (though, from my understanding, it will not fit). Keep in mind, you can NOT install pumps that aren't variable voltage style, otherwise they will not flow properly, and they will eventually burn up.
    Another potential upgrade could be upgrading the FPCM to the one from the ZR1 (as mentioned as a potential substitute in the above thread), but ONLY if it outputs more than 12.8v (doubtful). With this being said, I have NOT tested a ZR1 FPCM to see if it allows a higher output voltage, so I cannot guarantee that it'll work. If it does, and if it'll work, then that would be great for increasing fuel volume to the rails.
    On a slightly difference vehicle note, in regards to the 2010+ Camaro SS, LPE offers the CTS-V fuel pump assembly upgrade, as well as an FPCM upgrade, as seen here.
    Edit: I've been informed that it's kitted together by ADM, as seen here. Lonnie's Performance also sells something similar (I do not know if it includes an FPCM or not?), as seen here and here (scroll down to Gen5 section)
    I'm not 100% sure what LPE means by a "reprogrammed" FPCM, but my guess is that ADM is including the factory Caddy FPCM (attempting to ask LPE is worthless, and although they make good products, they are a bunch of pricks and dipsh!ts over there - see here). However, keep in mind, the Camaro is limited to 4-bar (58.x psi) with the factory fuel setup, as there is an in-tank fuel pressure regulator that limits it to such (see picture of such here). Going with the Caddy system, this would allow pressures higher than 58 psi to be commanded via the tune for these cars.
    Anyway, I hope this helps. I'll put up another thread in regards to tuning, and information about how to properly do such, especially on forced induction vehicles. A LOT of you would be shocked at how "hacked" tuning is these days (zero MAF table tuning and raped PE tables, raped spark tables, non-renormalized airmass axes, etc).
    Regards,
    James
    NC_Cadzilla's Avatar
    NC_Cadzilla is offline Cadillac Owners Fanatic
    Automobile(s): 2010 cts-v
    Jun 2010
    Garner, NC
    45
    200
    Re: CTS-V2 Fuel System Warning - Important!
    good to know info right there.. thanks
    gonfishin is offline Cadillac Owners Connoisseur
    Dec 2007
    4,150
    Very informative post and would like to hear from Jesse or others to see what they have done to remedy this issue.
    newcadman is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 cts-v
    Apr 2010
    961
    Very well researched, written and presented.
    Info to help prevent engine damage or grenading an engine is always most welcomed and appreciated.
    Thanks for sharing.
    Can't understand though why D3 with their " expertise" in research and development haven't outlined any of this information?
    e6t
    e6t is offline Cadillac Owners Connoisseur
    Automobile(s): V2 CTSV
    Jun 2010
    1,199
    Quote Originally Posted by newcadman View Post
    you should change your name to d3hater.
    and to the OP: while still over my head at this point, your post was very informative.
    Apr 2010
    961
    Quote Originally Posted by e6t View Post
    You mean they don't have any expertise in research and development and don't "work closely with GM engineers"?! Oops.
    Domsz06 is offline Cadillac Owner
    Automobile(s): 2009 CTS-V, 2007 Z06
    Jul 2010
    Houston Area
    38
    2,843
    I'd like to see more info on this and what not. It contradicts what every tuner says about nit needing any injectors till 600 rwhp.......
    I like the article and think I may have to add another mod to my list when I get around..... Boost a pump.
    snzuloz's Avatar
    snzuloz is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V / 2015 Porsche Cayenne
    May 2010
    Look up Way up
    725
    Unless I am reading into this wrong isn't this hp level supported changed if the injectors are increased in lb/hr? I mean the duty cycle shouldn't be approaching near the 100% max if the injectors are flowing more than the stockers. With two 190l/ph pumps you would think the pumps are capable of flowing enough fuel for those 600+ WHP setups. Really would like some more info and recommendations.
    mpouls1's Avatar
    mpouls1 is offline Cadillac Owners Enthusiast
    Automobile(s): '09V 11.99@118mph stock, '15i Escalade ESV, '03 Silverado LT
    May 2009
    iatethebones
    646
    mmm...delta P
    Jul 2010
    Houston Area
    38
    2,843
    Quote Originally Posted by snzuloz View Post
    yeah me too me too
    RWTD's Avatar
    Jan 2009
    42
    38
    Quote Originally Posted by Domsz06 View Post
    You're exactly right, it does tend to contradict what some "tuners" have been stating (not all, and I am not pointing fingers, so please do not think I'm insinuating such). This is simply a lack of information (not datalogging properly) and experience on their part (not understanding how flow and pressures actually work, especially in relation to a boosted vehicle). These are generally the same tuners (aka "tooners") who hack your tunes (you should see some of the tunes I have come across from other so called tuners, including ones from CTS-V2s).
    Also, in regards to quoted power numbers, I don't inflate numbers, and I quote Actual/Uncorrected for component limit ranges. I also use a Dynojet 224xLC, and my dyno numbers are inline with realistic numbers from other "honest" dynos. Yes, there are dynos that give higher output numbers. This is rare on Dynojets. However, when I first received my dyno back in 2005 (I was using another local one the previous 12 years before that), the calibration file that was sent with my software was for another Dynojet owner, which actually caused my dyno to read approx. 10% high, LOL! Talk about fun before I figured it out.
    Everyone, please re-read my initial post of this thread, as I have modified it to make it easier to understand, as well as included more information/data on the fueling issue, including addressing the issue with the pressures snzuloz speaks of. If you still have questions after that, please chime in.
    Sincerely,
    James
    Jul 2010
    Houston Area
    38
    2,843
    So it kind of sounds to me like adding a boost a pump for bills and your good to go. Injectors too if you want.
    This right James or am I missing something?
    Jul 2010
    Houston Area
    38
    2,843
    James. Do you have an email addy? Was gonna pm you but I can't....
  16. #14
    Bushidopupil is offline Cadillac Owners Enthusiast
    Automobile(s): (V)icious Coupe
    Sep 2010
    FL Panhandle
    709
    Second that email request!!!! Very good info, thanks.
  17. #15
    snzuloz's Avatar
    May 2010
    Look up Way up
    725
    I would venture to say that there is a limit set on max fuel pressure regardless of what is being "requested". I still think that the injector swap would change these findings, as the fuel pressure no longer would be required to hit those levels of "requested" pressure. I can't picture the idea of having a limit set on pump flow (regulator), it would be much easier to program out the max by limiting the max fuel pressure perhaps?
  18. Remove Advertisements
