Excessive Brake Pad Dust?
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
2009-2015 Cadillac CTS-V Performance Mods Discussion, Excessive Brake Pad Dust? in Cadillac CTS-V Series Forum - 2009-2015; I just picked up my new CTS-V last Thursday. I've put about a thousand miles on it so far and ...
    ebferro is offline Cadillac Owners Member
    Automobile(s): CTS-V
    May 2003
    PA
    62
    54
    I just picked up my new CTS-V last Thursday. I've put about a thousand miles on it so far and it's great. I've got about 500 miles on it since I last washed it and there's a fair amount of brake dust on it. Most of those 500 miles were interstate miles so not a lot of brake applications were made. Is the brake dust normal? There seems to be more on the driver's side front wheel than the passenger side front wheel. There's nothing on the rears. Anyone else experience this?
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Re: Excessive Brake Pad Dust?
    Normal. It's going to be hard to find pads that work with the enormous calipers and don't throw out any dust...
    gonfishin is offline Cadillac Owners Connoisseur
    Dec 2007
    4,150
    Quote Originally Posted by ebferro View Post
    Excessive break dust is normal. I too get a little more dust on one front wheel than the other, although cannot recall which one it is. I want to say the driver side is slightly more dusty.
    shade Guest
    The dust collected on these monster brakes is nothing to my SRT8. It also had 6 piston calipers and damn those things got much dustier, much quicker.
    SlvrBullIT is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V
    Jun 2009
    557
    Bed the pads, less dust IMHO. Still some but not near as much as the first week I had the V.
    Dec 2007
    4,150
    Isn't the pad material the main reason for dust. Get the semi metallic pads with stainless steel brake lines. Should improve braking w less dust.
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,781
    Yes, it is the pad material. I wouldn't go to semi-metallic since that might wear the rotors then too. I have never had a bad experince with ceramic pads and will get a set as soon as mine wear out.
    GMX322V S/C's Avatar
    GMX322V S/C is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V, 2009 535i
    Dec 2008
    SoCal
    1,840
    I can't wait. Having Hawk Ceramics put in next week. I hope they kick out less dust while remaining as quiet as my stock pads have been. lavaman and at least one other forum member are running them, hopefully they'll chime in with a report...
    Prof's Avatar
    Prof is offline Cadillac Owners Enthusiast
    Nov 2008
    Wadsworth, IL
    826
    "Bedding" the brakes does help...but performance machines use and need excellent brakes. Without dust, you don't have the stopping power you need in this wonderful vehicle.
    I am a little (well a lot) compulsive...I remove the wheels on both of my performance cars weekly to clean and fondle...
    Here is a wonderful site that explains the process of "bedding brakes" and explains the need for the process.
    http://www.zeckhausen.com/bedding_in_brakes.htm
    shchow's Avatar
    shchow is offline Cadillac Owners Fanatic
    Automobile(s): 2014 CTS-V; 2010 Escalade ESV
    Mar 2010
    Hainesport, NJ
    50
    464
    Same problem with the dust.
    Also, the brake dust has this oily residue and is a PITA to clean off.
    Any suggestions other than elbow grease?
    JFJr's Avatar
    JFJr is online now Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V (TR-6060, Black Raven/Ebony, Recaros, Ultraview)
    Jan 2009
    Jacksonville, FL
    73
    1,643
    Quote Originally Posted by shchow View Post
    Griot's Garage has an excellent wheel cleaner; spray it on and let it sit for a minute, give the wheel a light spritz with the hose nozzle and wipe the dust off with a wet sponge. Very little effort needed.
    Jeffrey is offline Cadillac Owners Fanatic
    Automobile(s): 2009 & 2016 CTS-V
    Aug 2009
    Texas
    182
    Quote Originally Posted by JFJr View Post
    Hi,
    Is it safe to use it on clear coated wheels?
    Thanks,
    Jeffrey
    JFJr's Avatar
    Jan 2009
    Jacksonville, FL
    73
    1,643
    Quote Originally Posted by Jeffrey View Post
    Hi,
    Thanks,
    Jeffrey
    Yes, I have been using it for years with great results.
    BTW if any of you hate to clean wheels, bring your car to me and I will clean your wheels for a mere $1,000 per car. Ha haa!
    Jud
  16. #14
    6speeder is offline Cadillac Owners Fanatic
    Feb 2010
    62
    293
    YES! Mothers foaming "all wheel and tire cleaner". They claimed spray it on, let it sit, hose it off and you don't have to touch the wheels.
    Well, with my previously waxed wheels, the stuff worked
    No touching and no residue or water spots.
  17. #15
    IRONDOG is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2008
    Dewitt, Michigan
    145
    Hi,
    Thanks,
    Jeffrey
    I think our manuals state only use soap and water.
  18. Remove Advertisements
