P-valve Question - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 72
Like Tree2Likes
2009-2015 Cadillac CTS-V Performance Mods Discussion, P-valve Question in Cadillac CTS-V Series Forum - 2009-2015; Originally Posted by backup I am really curious about this mod. I smell cheap HP! Here is what I found: ...
  1. #16
    CadV is offline Cadillac Owners Connoisseur
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    Re: P-valve Question
    Quote Originally Posted by backup View Post
    1. Disconnected O line. Found boost seemed slower to build and didn't quite reach 9psi
    2. Disconnected X line with O still disconnected. Seemed very similar to step 1 - slower to build boost and barely reached 9psi.
    3. Re-connected O, left X disconnected. Seemed to build boost VERY fast, and quickly pegged 9psi. Seat of the pants meter felt this was more responsive and more power, perhaps from faster boost build (more power sooner).
    I then reconnected all vaccuum/pressure lines and disconnected the electrical connector to the O/X valve device. Noticed it would still move the boost gauge while reving in neutral, haven't had a chance to drive it like that yet.
    I want to know what the X, O, P and V lines do, and how the valve and pressure regulator work to control boost. I don't understand how this functions. I got a hunch doing some tricks here will yield power. I want to know if the measured boost pressure as shown on the gauge is used to control the boost level, or whether it is governed by a separate mechanism such as this XOPV vaccuum/pressure valve assembly. It makes me think the 15psi shown above is real, although I don't know why the gauge would drop to zero - if the gauge information is indepependent from the boost control mechanism (the computer reading 9.0psi is not used to govern that boost).
    I do know the X/O valve is NOT the boost gauge as I was getting readings with the thing disconnected, both electrically and vaccuum lines.
    Cool post and I will play along. I will have time this weekend to mess around with it. Let me know what you find out and I will try it and see if we get the same results. I will also talk to my GM buddy and see if I can find out what POXV do.
    If you take the unit out you can grab the silver bar in this post:
    http://www.cadillacforums.com/forums...ml#post1943911
    and push it in and out. Once you cap p it is much harder to do so I assume boost is preserved.
  2. #17
    The Tony Show's Avatar
    The Tony Show is offline See you in the funny papers
    Automobile(s): 04 CTS-V, 05 STS, 07 SRX- All sold :(
    Dec 2004
    The Internet
    26,239
    You guys are ballsy, I'll give you that.
    Rest in Peace, J.D. (aka Dirt_Cheap_Fleetwood)
  3. #18
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    Here is a diagram
  5. #19
    Nutz's Avatar
    Nutz is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS-V a tuxedo with a jetpack!
    Oct 2007
    Northeast Ohio hammer down
    49
    2,460
    Well, somebody's gotta ask. Curiosity tugs. Which one is the "X" line? Or are they marked?
    Not that I would unhook it without seeing substantial evidence here to support or deny any imminent dangers.
  6. #20
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    Quote Originally Posted by Nutz View Post
    Check the first picture in post 6. See the x and o in green? x is cable 2 in the diagram. o and p is cable 4. cable 3 is v and other end is not labeled on mine.
  7. #21
    Nutz's Avatar
    Oct 2007
    49
    2,460
    Wow, small. Thanks.
  8. #22
    backup is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTSV, silver, manual
    Mar 2009
    Indiana
    213
    Great diagram! thanks. Got a legend to go with that? Knowing the official nomenclature for these parts would help understand what they do.
    CadV, did you cap the port in the supercharger housing that X connect to?
    Thinking this through a bit, here is what I have. The X line port is under vaccuum at idle, and presure at boost. This pressure feeds the X port on the XO valve. The O line feeds the P port on the pressure regulator device. The other port on the pressure regulator device is the V line that connects to something under the supercharger. I was thinking the V line transferred intake manifold vaccuum to the regulator device, to be balanced by the pressure from the P port, but that doesn't make sense because under boost there is no manifold vaccuum. So what the hell does the V line connect to?
    If pressure on the P port offsets vaccuum on the V line, and the two work together for some equilibrium to regulate boost, then I can see how capping the P port would allow the V line to maximize its variable. Assuming the V line is the positive feedback signal (increasing boost) then we would not want to cap that, but would want to cap the negative feedback signal (the P port). Capping the O port on the supercahrger housing might preserve some amount of manifold pressure just from eliminating the release that would occur if uncapped. Disconnecting the electrical connection on the XO valve should have no effect as long as the P port is capped. This is what I will test next.
    Is there such a thing as a wastegate on a supercharger? How is excess boost bled off? Or is it all controlled with a throttle or pressure plate (which would explain the pressure regulator adjusting a butterfly valve of some sort)? Experts we need your help!
  9. #23
    Nutz's Avatar
    Oct 2007
    49
    2,460
    Just what us men need, another difficult to understand little p valve that can make more blower pressure and increase whining AND can be quite volatile and very expensive to maintain if not delicately handled by an experienced professional.
    O.k, o.k, Sorry guys the door was open.
    Back to the regularly scheduled technical discussion.
  10. #24
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    I will try to get it tomorrow.
    No I did not. I did not cap the other end of P either.
    See the bolt holes on the blower snout? Go down you you will see a port pointing passenger side. V goes into that.
  11. #25
    Mar 2009
    Indiana
    213
    Quote Originally Posted by CadV View Post
    See the bolt holes on the blower snout? Go down you you will see the a port sticking out. V goes into that.
    Yeah but what is that? What does the V port connect to, inside the engine? If that is intake manifold, then the pressure should be the same as the supercharger housing. If the V port offsets pressure from the P port then I would assume it is pressure, not vaccuum, and the net presssure sets the regulator position. I am at the edge of my understanding of engine design, so somebody help me here. Maybe there is a difference between the pressures at the supercharger core (X port) and the intake manifold (V port)? And this difference regulates the boost??
    I just capped my P port line with a heavy dose of electrical tape. If my theory is right then I should see increased boost. Might need to cap the X port on the supercharger housing also. This also jives with what I saw by disconnecting the X line and the increased boost response (the V port was left unbalanced or unrestrained). But at atmospheric pressure the P port may have still offset the V line impact, so capping it might let the V line vaccuum (or pressure) maximize its effect. I will find out!
  12. #26
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    You lost me at regulator position haha. If you find anything let me know and I will test it too.
  13. #27
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    Here is the legend...
  14. #28
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,997
    The p port is basically for overboost situations. The P or "Protection" port will bleed off boost by opening the boost bypass valve when it reaches levels over stock. It is that way so even if you remove the limits inside the computer to still allow boost past 10psi, the valve will try to bleed off boost on its own. So by capping the line and venting the p valve will make it apply full boost without reventing the boost into the manifold to be recirculated.
  15. #29
    stealthjr is offline Cadillac Owners Fanatic
    Automobile(s): '09 Thunder Gray CTS-V
    Apr 2005
    Texas
    47
    156
    Quote Originally Posted by wait4me View Post
    Thanks for the clarification Jesse. So, I assume there is ZERO benefit to messing with this UNLESS one has a pulley to increase boost over stock levels right???
    Also, to avoid some confusion...you are saying to "CAP or plug" the P-Port LINE and vent or leave the "nipple" that the P-Port line was attached to...open? It looks like CADV capped the "nipple" on the valve and not the "line" as you stated. Just making sure I understood you correctly so folks on here dont mess something upo or do something backwards because of a misunderstanding of words.
    Thanks,
    Robert
  16. #30
    wait4me's Avatar
    Jan 2009
    warsaw indiana
    2,997
    Correct, Even though you get about .5 lbs of boost extra by tweeking the bypass valve on the stock one to make it fully closed. Even a slight gap will cause a pressure loss, so make sure it is fully closed.
  17. Remove Advertisements
