Got an odd wobble/sway back and forth on hard exceleration
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
2009-2015 Cadillac CTS-V General Discussion Discussion, Got an odd wobble/sway back and forth on hard exceleration in Cadillac CTS-V Series Forum - 2009-2015; What could this be. I have no whine from the rear diff but I suspect its not keeping up. Does ...
    CavemanB52's Avatar
    CavemanB52 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTSV coupe
    Aug 2012
    1,583
    What could this be. I have no whine from the rear diff but I suspect its not keeping up. Does it need to be flushed or is something else broken?
    CavemanB52's Avatar
    Aug 2012
    1,583
    Maybe a bushing in the suspension fell out?
    CavemanB52's Avatar
    Aug 2012
    1,583
    Anyone even have a clue what this might be? It doesn't do this all the time. But I do notice its more likely to happen after a hard shift. M6
    austin's Avatar
    austin is offline Cadillac Owners Connoisseur
    Automobile(s): ~2011 CTS-V Coupe & 2013 SRX~
    Apr 2005
    Boston, MA
    1,749
    I would drop it off at the dealer. It could be;
    (1) A slightly Bent rear Rim.
    (2) A Rear CV Joint failing.
    (3) A bad rear tire where the belt has shifted.
    CavemanB52's Avatar
    Aug 2012
    1,583
    Quote Originally Posted by austin View Post
    I have new tires all around. Never hit or ran over anything to have a bent rim. But I do plan on taking it in to see what's going on. Really weird symptom though.
    CavemanB52's Avatar
    Aug 2012
    1,583
    Really? No one else has had this? A CV joint does sound very possible. I'm the only one who has had this issue. I guess that's a good thing.
    Haze is offline Cadillac Owners Member
    Automobile(s): CTS V Wagon
    Dec 2011
    Philadelphia, PA
    96
    Re: Got an odd wobble/sway back and forth on hard exceleration
    Could be a blown shock. I had one go on the left rear, and it made the car drive pretty squirmy. Take it in.
    CavemanB52's Avatar
    Aug 2012
    1,583
    Quote Originally Posted by Haze View Post
    Thanks. I'm sure its something simple. I just was surprised it wasn't more common. I guess I'm a little hard on my car but I just can't help it.
    Dec 2011
    Philadelphia, PA
    96
    Quote Originally Posted by CavemanB52 View Post
    I'm not too hard on my car, and I have read about others having shocks go. I checked mine myself to find oil all over it before I took it in so I could tell the dealer exactly what to do. They weren't too happy about it, but it was bad.
    CavemanB52's Avatar
    Aug 2012
    1,583
    Did they warranty it?
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,674
    Hello CavemanB52,
    After reading the thread I see you are willing to bring your vehicle into your dealer. I apologize for the vehicle concerns you are experiencing. If you would like our assistance while working with the dealer, please let us know. Contact us via private message and include your full contact information, VIN, current mileage and dealer name.
    Sincerely,
    Laura M.
    Cadillac Customer Care
    CavemanB52's Avatar
    Aug 2012
    1,583
    Quote Originally Posted by Cadillac Cust Svc View Post
    Hello CavemanB52,
    Sincerely,
    Laura M.
    At the dearler now. Hopefully its something simple that just needs to be tightened. Or a simple part replacement. Ill let you all know.
    Mar 2010
    Detroit, USA
    12,674
    Thank you, CavemanB52. I will be on the lookout for any messages from you.
    Sincerely,
    Laura M.
  16. #14
    JFJr's Avatar
    JFJr is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V (TR-6060, Black Raven/Ebony, Recaros, Ultraview)
    Jan 2009
    Jacksonville, FL
    73
    1,643
    Have you had the tie rod TSB done? There have been reports by forum members spinning out because the nuts were loose.
    Jud
  17. #15
    CavemanB52's Avatar
    Aug 2012
    1,583
    Quote Originally Posted by JFJr View Post
    Jud
    Not sure. But I doubt that is the issue based off the symptoms I had. I took it in to the dealer and changed the rear diff fluid just to do it. The mechanic inspected everything and tightened up the sway bar and solved all the issues. I guess I just loosened the sway bar. Somehow. No cost and everything is all better. Thanks cadillac of las vegas for doing a good job that didn't cost me anything.
  18. Remove Advertisements
