2012 CTS-V Wagon - Remote Start Questions
Results 1 to 15 of 15
2009-2015 Cadillac CTS-V General Discussion Discussion, 2012 CTS-V Wagon - Remote Start Questions in Cadillac CTS-V Series Forum - 2009-2015; Is there any reason why the remote start would not work today for me? It worked this morning and earlier ...
    Fieldgoal00 is offline Cadillac Owners Member
    Jun 2013
    36
    65
    Is there any reason why the remote start would not work today for me? It worked this morning and earlier today for me. However when I tried to do it just a few minutes ago, the car would not start. I even made sure to lock the car first before trying to hit the remote start button. I then hit the remote start button twice like you are supposed to do, and all the car did was blink the turn signals in the head light twice and that is all it did. Any suggestions?
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,781
    Re: 2012 CTS-V Wagon - Remote Start Questions
    I hit the lock, and then the start button once and hold until it fires. I've never had to hit mine twice.
    gohawks63's Avatar
    gohawks63 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Black Diamond CTS-V Coupe
    Feb 2008
    54
    3,350
    Quote Originally Posted by Fieldgoal00
    Are you low on fuel?
    vfaninva's Avatar
    vfaninva is offline Cadillac Owners Master
    Automobile(s): Prev; '09 V sedan, '13 V coupe, '16 C7 Z51. Cur; '12 C63 AMG coupe. Next; '16/'17 V3
    Dec 2012
    Virginia Beach, VA
    53
    5,813
    Push the lock button once, then press and hold start button.
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,840
    Quote Originally Posted by vfaninva
    +1. I hold the button down until the lights blink and it fires.
    dnevels's Avatar
    dnevels is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V wagon
    Jul 2013
    29
    Quote Originally Posted by Fieldgoal00 View Post
    That has happened to me before . Come to find out I did not turn the key completely back on off position. Check and see
    Jun 2013
    36
    65
    Read the manual, there is no problem. The issue is that you can only remote start the vehicle two times before you have to actually start the car inside of the car. It won't let you try and remote start it more than 2 times.
    6104696 is offline Cadillac Owners Connoisseur
    2,178
    I think all GM's require hitting lock button, then push and hold in the remote start button until it fires (actually until the lights blink, I think). I don't think you are supposed to hit the remote start button twice.
    Never had a problem with the suburban. My CTS-V is a manual, so no remote start. If there is any drawback to the manual trans. (for me, that is), the lack of remote start is it......it's the greatest feature ever for hot summer days and cold winter days......
    baabootoo's Avatar
    May 2010
    Racine, WI
    3,781
    Ahhhhhhhhhhh, details...........
    Snotty Boom Body is offline Cadillac Owners Fanatic
    Automobile(s): 13 V Coupe Thunder Gray
    Mar 2013
    244
    Quote Originally Posted by 6104696 View Post
    You can get an aftermarket remote start for the manual trans cars if you want.
    Also if you happen to have a check engine light ON or if the hood is open the remote start will not work.
    You can only remote start 2 times before you have to use the ignition key to start.
    Each remote start only lasts for 10 minutes and then shuts off.
    If your getting near the end of the first 10 minute time interval and want to run the car longer you can push your lock button and remote start button again while the car is running and it will continue for another 10 minutes from that point. After that you have to use the ignition again.
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    This info should be in your owners manual. This is straight out of the STS/STS-V manual. It's probably the same for you guys:
    "The remote start feature will not operate if any of the following occur:
    • The check engine light is displayed. See “Check Engine Light” under Malfunction Indicator Lamp on page 252.
    • The valet lockout switch is on.
    • The keyless access transmitter is in the vehicle.
    • The vehicle’s hood is open.
    • The vehicle personalization feature is not enabled.
    • An unauthorized vehicle entry or a vehicle theft was attempted."
    Feb 2013
    Whitestone, NY
    28
    3,211
    Also looking through the forums I've learned that if a fob is not programmed as either driver 1 or driver 2 it won't start the car.
    gohawks63's Avatar
    Feb 2008
    54
    3,350
    Quote Originally Posted by Guy.Seminerio
    This info should be in your owners manual. This is straight out of the STS/STS-V manual. It's probably the same for you guys: "The remote start feature will not operate if any of the following occur: • The check engine light is displayed. See “Check Engine Light” under Malfunction Indicator Lamp on page 252. • The valet lockout switch is on. • The keyless access transmitter is in the vehicle. • The vehicle’s hood is open. • The vehicle personalization feature is not enabled. • An unauthorized vehicle entry or a vehicle theft was attempted."
    Valet switch? What valet switch?
  16. #14
    Feb 2013
    Whitestone, NY
    28
    3,211
    Ok just did a bit of research. I guess that's a difference. Cts doesn't have valet mode. Ignore that one. My bad.
  17. #15
    gohawks63's Avatar
    Feb 2008
    54
    3,350
    I got all excited.
  18. Remove Advertisements
