Rear end fluid capacity
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Snotty Boom Body
2009-2015 Cadillac CTS-V General Discussion Discussion, Rear end fluid capacity in Cadillac CTS-V Series Forum - 2009-2015; Guys Picked up a 12 Sedan V and I want to change out the read diff fluid. Can anybody tell ...
    Mikevette is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V , 2011 CTS-V Coupe, 2012 CTS-V Sedan
    Jul 2007
    Crestview, Fl
    55
    232
    Guys
    Picked up a 12 Sedan V and I want to change out the read diff fluid. Can anybody tell me the capacity or how much Amsol I'll need to purchase? I'll go by GM and get a small bottle of the limited slip additive also.
    Thanks
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    692
    Re: Rear end fluid capacity
    You need two quarts. I put in about 1.75 quarts when I changed mine last week. Amsoil said you don't need the additive but people have had mixed experiences. I chose to just add the 70ml of additive to avoid messing with it any further. It's been nice and quiet since I changed it (was quiet before too).
    PNBLWZD is offline Cadillac Owners Fanatic
    Jun 2010
    Los Angeles, CA
    46
    303
    1.8 qts. When my friend's shop did mine last week he said the current GM fluid has the limited slip additive already mixed in. Nothing more needed
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Quote Originally Posted by spearfish25 View Post
    Who at Amsoil? Amsoil HAS CONFIRMED additive is needed for the V2. Not so for the V1.
    A bottle of additive and about 1.5 quarts of Severe Gear...
    Snotty Boom Body is offline Cadillac Owners Fanatic
    Automobile(s): 13 V Coupe Thunder Gray
    Mar 2013
    244
    Quote Originally Posted by thebigjimsho View Post
    who at amsoil? Amsoil has confirmed additive is needed for the v2. Not so for the v1.
    A bottle of additive and about 1.5 quarts of severe gear...
    x2
    thebigjimsho likes this.
    May 2013
    Naples, FL
    692
    LOL. I copied it for you already. I do get a slight rub when I first drive in the morning. Might need the whole bottle of modifier.
    Here:
    Alex,
    The Severe Gear line already has added friction modifier. Applications that require more than 4 oz of friction modifier may need additional product added if there is gear chatter.
    Ashley
    AMSOIL Technical Services Representative
    AMSOIL INC- AMSOIL Building
    Superior, WI 54880
    TEL 715.392.7101 EXT 6098 -FAX 715.392.3097
    www.AMSOIL.com
    Automobile(s): ZIP
    51,885
    http://www.cadillacforums.com/forums...ormulated.html
    Although the link doesn't work. Ah well...
    AC Promotions's Avatar
    AC Promotions is offline Cadillac Owners Member
    Automobile(s): 2013 CTS-V Wagon-Manual Transmission
    Dec 2010
    Flower Mound, Texas
    61
    Add the GM friction modifier since it is supposed to be present if you have a rear end warranty claim.
    Unfortunately it causes any diff fluid to be more apt to break down since it goes into thermal runaway so
    easily. Change the fluid regularly if you engage in Motorsports.
    Jul 2007
    Crestview, Fl
    55
    232
    CoolRe: Rear end fluid capacity
    That's guys for all your input, I'll add the friction modifier for comfort and cheap insurance.
    thanks again
    Mike P.
    LSUFoolsball is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-V Sedan All options
    Feb 2013
    34
    40
    where are the plugs? Pics please
    May 2013
    Naples, FL
    692
    After adding a whole bottle of the GM modifier, I was still getting some rubbing sounds from the diff when I'd turn the first couple times after the car sat. Took it back to the dealer, they swapped the GM fluid back in and all is quiet again.
    Think I just needed more modifier than one bottle?
  14. Remove Advertisements
