Clutch Grabbing - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Like Tree1Likes
2009-2015 Cadillac CTS-V General Discussion Discussion, Clutch Grabbing in Cadillac CTS-V Series Forum - 2009-2015; You may be releasing the clutch too slowly. On level ground don't even need throttle, just a smooth quick release ...
  1. #16
    jb_bgg is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Black/Black V, Manual, Recaros, loaded
    Feb 2011
    Orange County, CA
    254
    Re: Clutch Grabbing
    You may be releasing the clutch too slowly. On level ground don't even need throttle, just a smooth quick release (half a second or so.) Up a grade, maybe a steady 1000rpm until fully engaged...
  2. #17
    Mr. Hyde's Avatar
    Mr. Hyde is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V Coupe
    Jun 2013
    Seattle
    56
    220
    Re: Clutch Grabbing
    My 2008 C6Z did the exact same thing. I learned to live with it.
  3. #18
    JFJr's Avatar
    JFJr is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V (TR-6060, Black Raven/Ebony, Recaros, Ultraview)
    Jan 2009
    Jacksonville, FL
    73
    1,643
    BTW, the V2 clutch is far superior to the "sticky" clutch on the last Porsche Boxster I drove. I've never driven an underpowered stick shift econobox, so I haven't been "spoiled."
    Jud
  5. #19
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    692
    Less definitely isn't 'more' in my case. Letting out the clutch without throttle will stall.
  6. #20
    JFJr's Avatar
    Jan 2009
    Jacksonville, FL
    73
    1,643
    Quote Originally Posted by spearfish25
    I discovered it in a parking garage; it's spooky and in the old days would lead to bucking and eventual stall. Well, we all have to get used to that and auto rev, for the future. As long as we can turn off some of this electronic crap, it's fine (except DOD which is totally overkill, stupid and made for a Buick).
    Jud
  7. #21
    sybersport is offline Cadillac Owners Fanatic
    Automobile(s): 2011 White Diamond CTS-V
    Jun 2010
    Toronto
    283
    Re: Clutch Grabbing
    I have the exact same issue - but it hasn't proven to be a problem. She can still get herself down the track pretty quick (12.3!)
  8. #22
    May 2013
    Naples, FL
    692
    Dealer claims its normal and should be better now that they 'topped off' the clutch reservoir. Please.
    I guess I'll live with it for now. When it fails I'll at least have it documented already.
  9. #23
    JFJr's Avatar
    Jan 2009
    Jacksonville, FL
    73
    1,643
    I've had my clutch fluid replaced twice under the normal maintenance schedule and it made no difference in clutch operation, but I really don't have a problem with it. Hopefully, your dealer wasn't selling you unnecessary maintenance.
    Jud
  10. #24
    Xaqtly's Avatar
    Xaqtly is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 WD Vagon 6MT "Unobtainicorn"
    Jan 2012
    Las Vegas, NV
    1,276
    Re: Clutch Grabbing
    Quote Originally Posted by Random84 View Post
    How is a long engagement (intentional slip) better for the clutch?
    Because it's much lower RPM, therefore there is less friction between the clutch disc and the flywheel, therefore extending the life of your clutch. Higher RPM means a higher rotational difference between the disc and the flywheel, which generates more friction, more heat and the loss of more clutch disc material. So while doing it the low and slow way may take longer, it's actually easier on your clutch disc due to lower friction due to lower rotational speed. And in fact I believe it grabs sooner too, because if the engine is lugging then the clutch disc is already attached to the flywheel and there is no friction being generated.
  11. #25
    May 2013
    Naples, FL
    692
    Re: Clutch Grabbing
    Quote Originally Posted by JFJr View Post
    Jud
    Yeah, no worries. I do all my car maintenance myself unless there are big issues or warranty work is necessary. So things like bleeding the clutch, I'd never ever pay a dealer for.
  12. #26
    cdog533's Avatar
    cdog533 is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V
    Apr 2004
    539
    Re: Clutch Grabbing
    Quote Originally Posted by Xaqtly View Post
    I'm not sure lugging it is the best approach. I like a nice slow engagement from like 2,000 rpms. This is smooth, prevents lurching, and does not drop you super low into the torque curve like a 750 rpm launch does.
  13. #27
    May 2013
    Naples, FL
    692
    Re: Clutch Grabbing
    Well, 1500rpm definitely helps. It also seems better now that my whining rear diff has been replaced by the dealer. It's now perfectly quiet.
  14. #28
    Xaqtly's Avatar
    Jan 2012
    Las Vegas, NV
    1,276
    Re: Clutch Grabbing
    Yeah higher RPM engagements are smooth, but like I said, it's more wear and tear on your clutch disc. I tried it a few times yesterday and I found I can avoid the chatter at 1100-1200 RPM, so 2000 probably isn't necessary. OTOH I also have a pulley, intake and a tune so I may be making a bit more torque at that RPM, not sure about that. Anyway ideally you always want to rev match when downshifting to minimize clutch disc wear, and starting from a stop you want to do it at as low an RPM as you can while still avoiding the chatter so you can have a smooth start while minimizing clutch disc wear. The idea is just to keep the rotational speed differential to a minimum when mating the disc to the flywheel, to preserve the clutch disc.
  15. #29
    JFJr's Avatar
    Jan 2009
    Jacksonville, FL
    73
    1,643
    That's my sweet spot, too, and my car is bone stock.
    Jud
  16. Remove Advertisements
