Trunk wont open
Page 1 of 2 12 LastLast
Results 1 to 15 of 27
2009-2015 Cadillac CTS-V General Discussion Discussion, Trunk wont open in Cadillac CTS-V Series Forum - 2009-2015; Went to work this morning and trunk will not open. It worked fine last night when I got home. I ...
    Chosenone is offline Cadillac Owners Member
    Automobile(s): 09 CTS V
    Nov 2012
    34
    87
    Trunk wont open
    Went to work this morning and trunk will not open. It worked fine last night when I got home. I have tried the fob and the door button and the trunk membrane button and none work. I can hear the trunk accuator working and clicking but trunk will not open. I tried the emergency release through the back seat and it wont work either. This happened once before a while ago and it finally opened. Any ideas?
    pat2t2f's Avatar
    pat2t2f is offline Cadillac Owners Enthusiast
    Aug 2012
    709
    Could something be caught in the mechanism?
    Nov 2012
    34
    87
    Re: Trunk wont open
    I dont think so. There was one bag in my trunk when I closed it last night. I pulled that bag out through the seat access hole this morning to make sure it wasnt stuck. Not sure what to do from here. I know a dealer is going to charge a lot to remove seat to get in there though.
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,814
    Re: Trunk wont open
    No warranty? When did you change the remote battery last? Mine was sporadic, changed it, and all was well.
    Nov 2012
    34
    87
    Re: Trunk wont open
    The remote works fine, all the other doors unlock, auto start works and the trunk you can here working, its just stuck. No warranty.
    MASCAD is offline Cadillac Owners Member
    Automobile(s): ATS4 3.6 2013; CTS-V COUPE 2011
    Jun 2009
    NORTHERN NEW YORK
    79
    Re: Trunk wont open
    Quote Originally Posted by Chosenone View Post
    Wonder if you could try using the emergency release again but this time have someone lift upward on the lid at the same time. Or maybe even push down to take pressure off the latch mechanism
    Nov 2012
    34
    87
    Re: Trunk wont open
    yeah I will try that when I get home from work tonight. Of course the cadillac seals the trunk up so tight that there is no access in there at all. Even the back seat trap door the actuator is all covered inside the trunk. So I am guessing I will have to pay a shop to remove back seat and the inside trim from inside the trunk to access the acuator. That should cost a large amount of cash.
    Nov 2012
    34
    87
    Re: Trunk wont open
    Anybody know how to remove back seat? Is it something I can do myself. Then does anybody know how to remove the trunk trim that covers the acuator inside of the trunk. I would need to remove back seat to get into trunk, then remove the gray beauty plastic that covers the latching mechanism I think.
    RobF300 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V sedan HIS, 2012 CTS4 coupe- Her's
    Jan 2013
    Amityville, New York
    317
    Re: Trunk wont open
    back seat usually entails pushing the ass part in and up, releasing the clips
    then it will expose bolts that you remove to get the backrest out
    unless you can access the bolts through a fold in the seats
    dont take this the wrong way but if you dont know how to remove a seat you probably dont know how to fix the trunk
    Nov 2012
    34
    87
    Re: Trunk wont open
    I know that but when I take the car into the shop to have the trunk looked at I would rather remove the seat myself then pay a shop rate of $75.00-$100.00 to do something I can do with a little help and direction which is what I was asking for. Also if for some reason the trunk latch is just tweaked or out of alignment and all it takes is to straighten it with some pressure or somehow something got stuck in there that just needs to be removed, then I would really cuss myself if I just paid the shop $100 plus dollars to tell me they put a little pressure on the latch and it works fine. Thanks for the insight on seat removal, anybody now how to remove the trunk trim from inside the trunk that covers the latch on the inside?
    Dogbreath is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Dec 2011
    Peoples Republik of MD
    62
    65
    Re: Trunk wont open
    Did you try using the old school metal key?
    Nov 2012
    34
    87
    Re: Trunk wont open
    There is no key hole to put a key in at on the trunk.
    VMoose's Avatar
    VMoose is offline Cadillac Owners Fanatic
    Automobile(s): 2013 Stealth Blue Metallic CTS-V Wagon
    Apr 2012
    Clarksville, TN
    231
    Re: Trunk wont open
    Have you tried disconnecting the battery for a bit to reset the electronics?
  16. #14
    shchow's Avatar
    shchow is offline Cadillac Owners Fanatic
    Automobile(s): 2014 CTS-V; 2010 Escalade ESV
    Mar 2010
    Hainesport, NJ
    50
    464
    Re: Trunk wont open
    Was the car ever rear ended or in an accident?
  17. #15
    mpouls1's Avatar
    mpouls1 is offline Cadillac Owners Enthusiast
    Automobile(s): '09V 11.99@118mph stock, '15i Escalade ESV, '03 Silverado LT
    May 2009
    iatethebones
    647
    Re: Trunk wont open
    You can hear the actuator and it won't release, and you tried the manual release and it didn't work. Leaning more towards the latch??? Try what MASCAD was saying and see if you can get someone else to help while you use the fob/emergency release while the other applies putting pressure up/ down on the trunk. Maybe work something lose. Hope this can be resolved without taking to a shop.
  18. Remove Advertisements
