Rear end symptoms? - Page 4
Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 58 of 58
Like Tree1Likes
2009-2015 Cadillac CTS-V General Discussion Discussion, Rear end symptoms? in Cadillac CTS-V Series Forum - 2009-2015; Originally Posted by cadzilla32 New diff installed yesterday. No noise now! Question: is there a recommended break-in procedure for the ...
  1. #46
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,840
    Quote Originally Posted by cadzilla32
    New diff installed yesterday. No noise now! Question: is there a recommended break-in procedure for the new rearend? I am a Manual Sedan. Thanks!
    Yes. Vary your speeds, no hard launches and no full throttle application for about 500 miles. Those are the cliff notes and what I did. It's more detailed in the manual, too.
  2. #47
    CavemanB52's Avatar
    CavemanB52 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTSV coupe
    Aug 2012
    1,583
    I was told 1500 mile break in by a GM engineer after they replaced mine. No hard launches and no hard excelerations try and keep it to gradual excellerations and the phosphate rear end will get stronger and stronger with use. Till then its brittle and can be broken.
  3. #48
    Trapspeed's Avatar
    May 2011
    Central Florida
    2,840
    Quote Originally Posted by CavemanB52
    In reality I don't thrash my car so I know it got at least that. I'm after longevity!
  5. #49
    cadzilla32's Avatar
    cadzilla32 is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac CTS-V
    Nov 2011
    65
    Thanks guys. Seems reasonable to ease her back into it.
  6. #50
    Trapspeed's Avatar
    May 2011
    Central Florida
    2,840
    You'll be happy you did. These powertrains, by in large, are tried and true strong.
  7. #51
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    692
    I had the rear end swapped at 4300 miles due to whine and the new one is silent. I've been babying her for 1000 miles and swapped the fluid yesterday. It was the best looking gear oil I've ever seen come out of a diff. Magnetic plug barely had anything on it too. Refilled now and just about ready to rock. I'm going to give her another couple hundred miles with the new stuff and then get to work on shaving the rear tires .
  8. #52
    CavemanB52's Avatar
    Aug 2012
    1,583
    Quote Originally Posted by spearfish25 View Post
    Sweet. Speeking of burning tires. I'm on my third set of rears. I've had the stock pilot sports 285 35, MT 305 35 and right now Michelin SS 295 35. Has anyone tried the new Nittos 305 35?
  9. #53
    boplaw's Avatar
    boplaw is offline Cadillac Owners Member
    Automobile(s): 11 CTS-V Coupe
    Nov 2009
    51
    Re: Rear end symptoms?
    Took it in a couple of months ago and they told me the tires needed replacing before they could diagnose it. Fair enough.
    New tires installed and took it back in 2 days ago. SA says "I hear it". He called this morning and said "I been over this with the service manager, our head technician, and Cadillac Tech. We believe that sound is normal".
    O'really? So why doesn't my business partner's sedan with the same miles make noise? So I can go drive drive one of yours out of the showroom and it will whine too, right?
    "Well, it may be your aftermarket exhaust rubbing on one of the heat shields". MmKay.
    Great customer service at Baker Cadillac.
  10. #54
    FLTRI's Avatar
    FLTRI is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 V-Wagon & 2012 SRX Premium
    Jul 2011
    Las Vegas, NV
    52
    1,004
    Quote Originally Posted by boplaw View Post
    If they haven't already done it, have them drain the fluid and show you the magnetic plug, before they clean it. Then ask them if the ton of metal shavings on it are normal. When they did mine, it was pretty obvious that it's not supposed to look like an oily fur coat...
  11. #55
    quikag is offline Cadillac Owners Fanatic
    Automobile(s): '12 White Diamond CTS-V Sedan, '10 Cyber Gray ZR1
    Dec 2005
    Dallas, TX
    40
    265
    Some really lazy dealers and some good ones. I had a HORRIBLE experience at James Wood Cadillac (Denton, TX), took it there 3 times for rear-end noise, even taking the shop foreman for a ride to help show him the noise. They end up driving my car over 50+ miles, changing the radio to a rap station, and messing up my front rotors (wonder how that happened!?!?). I was FURIOUS. They STILL didn't fix it. They claim to have fixed a bearing in the diff, but they totally lied as that's not an authorized repair for a diff noise and they never charged anything to Cadillac for warranty. They basically did nothing, except joy ride my car.
    Several days later, I drop my car off at Sewell Cadillac in Grapevine, TX at 7:30am or so. At 4pm ,they call and tell they have replaced the front rotors (new 2 piece!) and front pads and put a brand new diff in the rear-end. 8 hours later they had all that done! I show up at 5pm, the car is already washed and vacuumed out out and they put a whole 7 miles on my car diagnosing the noise. Perfectly acceptable to me. The rear-end is noise is completely gone and has been that way for many thousands of miles since then. Suffice to say, if Sewell Cadillac keeps that kind of service up, they have a customer for life.
  12. #56
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Hello boplaw,
    I apologize that you are experiencing this concern as well. If you would like me to contact your dealership regarding this concern, or would like me to set you up an appointment with another
    dealership for a second opinion, please private message me. I would need your name, contact info, VIN, mileage, and dealership you are working with. Thank you very much for taking the time to read my post.
    Gregory W.
    Cadillac Customer Care
    Quote Originally Posted by quikag View Post
    Hello quikag,
    I apologize that you had such a bad experience at the first dealership regarding this concern. I am happy to hear that you had a much better experience at Sewell Cadillac and that they were able to address the concern you were having. Please feel free to reach out to us via private message if you have any further questions or concerns. Thank you very much for posting your experience.
    Gregory W
  13. #57
    the blur's Avatar
    the blur is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Oct 2008
    NY
    1,014
    Is there a diff club ? I may be a member. 30,000 miles. It's a process, where you need to pay for a diff oil change. Then complain 3 weeks later that the noise is still present. And eventually they'll replace the rear. It's a $1500 part, and $1500 in labor if your out of warranty.
    One would think Cadillac would take a Corvette diff, and use it in the V. Something that will take the abuse of a super charger. Part of the problem is the rear tires loose traction in the cold weather. So your spinning the tires without even realizing it. 20 degrees out today, getting on the highway, and the rear is loosing traction. And I wasn't even on the throttle that hard.
  14. #58
    CavemanB52's Avatar
    Aug 2012
    1,583
    Sounds like cold tires and street conditions
  15. Remove Advertisements
