Strange observation on GM's AC system...
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
2009-2015 Cadillac CTS-V General Discussion Discussion, Strange observation on GM's AC system... in Cadillac CTS-V Series Forum - 2009-2015; So, I've owned a 2006 Chevy Express van, 2011 Chevy Express van, 2010 V and 2013 V. All have the ...
    taken is offline Cadillac Owners Fanatic
    Automobile(s): 2013 CTS V
    Jun 2011
    43
    210
    So, I've owned a 2006 Chevy Express van, 2011 Chevy Express van, 2010 V and 2013 V. All have the identical quirk in the AC. It runs ice cold for 2-3 minutes and then has 10-15 seconds of warm. Then it's back to a few minutes of cold. All 4 vehicles did it the exact same way. Theories? No other brand of vehicle I own or have owned does this.
    cruiser68 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS-V A6 Sedan Modded :)
    May 2011
    Chicagoland
    711
    Re: Strange observation on GM's AC system...
    My V does not exhibit that symptom. If I get on it however, it does shut off the compressor until you get off it.
    Jun 2011
    43
    210
    Strange. I thought it was a GM thing as the Express cargo van and the V are pretty much polar oposites and both did/do it the exact same way. 4 vehicles all the same. Could it be a huge coincidence? Mine has nothing to do with RPM. Does it no matter what. Cruising along a back road at 50 and low RPM still does it...
    MASCAD is offline Cadillac Owners Member
    Automobile(s): ATS4 3.6 2013; CTS-V COUPE 2011
    Jun 2009
    NORTHERN NEW YORK
    79
    Curious as to what part of the country you're in. Just tried my '11 CTS-V and it doesn't seem to act the way yours does (86 and humid) Does it do this when you first start the car, drive for a while etc. and does it ever not do it?
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,840
    Are you using the Auto setting? If so, that will do it every time unless you bottom it out or go all the way hot.
    May 2011
    Chicagoland
    711
    Quote Originally Posted by Trapspeed View Post
    Good point. I use auto and I can definitely tell when it gets gets cooled down as the vents do go from cold to "not as cold" but I wouldn't say warm.
    RGaret's Avatar
    RGaret is offline Cadillac Owners Enthusiast
    Automobile(s): None
    Mar 2009
    New York
    46
    525
    Quote Originally Posted by cruiser68 View Post
    Mine does the same thing. I leave it on auto all the time. Not every 4 minutes but it does blow warm for a few seconds every now and then.
    Jun 2011
    43
    210
    Yep, on auto. However, my van's didn't have auto climate control and did the same. Your right, it's not really warm, just "not so cold" for a few seconds as mentioned above. I'm sure it's normal, just not sure why it cycles. Have Ford and Dodge vehicles, both with auto climate control, that never have this fluctuation.
    Jinx is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 CTS-V estate
    Mar 2003
    Oakland, CA
    47
    1,243
    Maybe this is how they keep mold from growing.
    Jun 2009
    NORTHERN NEW YORK
    79
    Quote Originally Posted by taken View Post
    Could this be caused by cycling of the compressor to prevent icing of the evaporator coil.? As the system senses that ice is forming it may be cycling the compressor off for a short while which lets the ice melt and would cause the air to be not so cold. After the ice is melted the compressor kicks back in and the air becomes colder again. Ambient conditions especially humidty would be a factor on how frequently this occurs.
    Jun 2011
    43
    210
    That makes a lot of sense. Could be... Wonder why GM has it and no one else does?
    Jun 2009
    NORTHERN NEW YORK
    79
    Not sure why you don't notice this on other vehicles. Ive seen this icing happen on marine A/C units under certain conditions so I'm thinking it must happen to every system if the conditions are right. After all, the air going thru the A/C unit is the same regardless of the make of the vehicle!
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Once in a while the A/C cycles off for a few seconds in my Town Car...
  16. #14
    mr weather is offline Cadillac Owners Member
    Automobile(s): 2010 CTS-V Sedan
    Jun 2013
    Toronto, ON
    44
    88
    My wife's 08 Grand Caravan doesn't cycle and depending on ambient conditions (usually moderate temps but high humidity) the evaporator freezes up and I have manually "de-ice" it by turning the a/c off. What a stupidly designed system.
  17. #15
    montgb is offline Cadillac Owners Member
    Apr 2013
    Northern VA
    38
    34
    I noticed this behavior on my V today.
  18. Remove Advertisements
