steering misalignment
Results 1 to 9 of 9
2009-2015 Cadillac CTS-V General Discussion Discussion, steering misalignment in Cadillac CTS-V Series Forum - 2009-2015; So I was backing out of the driveway today and felt a little slip in the steering. Heard a little ...
    lokoh is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2006
    6
    So I was backing out of the driveway today and felt a little slip in the steering. Heard a little grunt from the front end and when I started moving forward, I noticed that my steering wheel was pointed about 30 degrees to the left when driving straight. Shortly afterward ,the service stabilitrac light came on and stayed on. So now, when driving in a straight line, my steering wheel is about 30 degrees off center. WTF is wrong here? My mods are eibach coils, intake and exhaust. That's it! Anyone else have this problem. Know what went wrong. 2012 M6 wagon with less than 2000 miles.
    Thanks
    V-swagon's Avatar
    V-swagon is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Fleetwood Brougham, 2002 DTS, 2011 CTS-V wagon
    Aug 2012
    Ohio
    39
    162
    Was everything torqued after the Eibachs were installed?
    Dec 2006
    6
    Re: steering misalignment
    Quote Originally Posted by V-swagon View Post
    I didn't install the coils myself, but the shop I use is pretty top notch. They do a lot of the Overhaulin cars here in Huntington Beach. I've been using them for years, without problems. Don't see how installing coils would affect the steering.
    V-swagon's Avatar
    Aug 2012
    Ohio
    39
    162
    The only reason why I asked is I just installed Eibachs on my V wagon. The front upper control arm has to come out along with the spring/strut.
    Mr.electric is offline Cadillac Owners Member
    Automobile(s): 2004 Deville
    Mar 2013
    80
    I would get it checked ASAP. I might even tow it into the shop. Something is loose and if it lets go while you are on the freeway it won't be pretty. Since the car still drives in a straight line it is probably something that effects left and right. The clamps and rubber bushings that hold the rack down could be loose. Anyways it does not sound safe to drive in my opinion.
    ctsvracingalan's Avatar
    ctsvracingalan is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Silver CTSV Sedan
    Feb 2012
    Nassau NY
    178
    When you lowered your car they may have forgot to adjust you steering shaft it needed to be adjusted and the steering knuckle may be hitting itself when you turn wheel
    Dec 2006
    6
    Problem was a loose bolt for the lower control arm adjustment slot. Shop realigned it and its all good now. Thanks for the help everyone
    ENVIOUS V is offline Cadillac Owners Member
    Automobile(s): 2012 Radiant Silver CTS -V, 1987 Buick Grand National
    Nov 2012
    SoCal
    51
    Hey at least you took care of it and the bolt didn't fall out.
    V-swagon's Avatar
    Aug 2012
    Ohio
    39
    162
    Quote Originally Posted by lokoh
    Good to hear that it's fixed.
  12. Remove Advertisements
