Cutting Stock Springs?
Results 1 to 13 of 13
2009-2015 Cadillac CTS-V General Discussion Discussion, Cutting Stock Springs? in Cadillac CTS-V Series Forum - 2009-2015; I have a 2012 Coupe. I recently had the Eibach Pro-kit lowering springs installed by a dealer. Although it is ...
    sunsalem is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V BR Coupe
    Jan 2012
    148
    I have a 2012 Coupe. I recently had the Eibach Pro-kit lowering springs installed by a dealer. Although it is a bit too stiff for everyday driving, the Eibach kit lowers the car to its "correct" height (IMO) and I love the way it now looks. Unfortunately, the springs squeak and local dealers are unwilling or unable to do anything about. I have decided it is probably best to remove the Eibachs and re-install the stockers. I am wondering if I can have the stock springs cut to reduce drive height (as the Eibachs do)? If it can be done, can or would a dealer do this? Would this cause any problems with the rest of suspension system? Can anyone give me some advice on this situation? Thanx.
    dqw1's Avatar
    dqw1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    Apr 2005
    Madison, AL
    55
    2,018
    Re: Cutting Stock Springs?
    I had my Eibachs installed earlier this week and they also have the noise I was warned about. The installers knew nothing about any kind of cutting so I have them installed per the instructions. I have to take mine somewhere to get the bump stops cut and dust cap removed. There is a thread somewhere with one guy cutting the stock springs. Not sure if it was on this forum or the other one. You would have to ask your SW if they would cut the stock springs but try to find some place experienced with suspension systems first.
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    May 2011
    Central Florida
    2,840
    You can really cut any spring but in doing so most likely you will screw with the geometry in the play since some coils and their location will affect the ride differently when they are removed. We did this a ton in high school and boy did our ride suffer! Just do your research, that's all.
    Jan 2012
    148
    Quote Originally Posted by dqw1 View Post
    Supposedly, with the Eibachs cutting bump stops or removing dust covers are unnecessary.
    Boosted2000si's Avatar
    Boosted2000si is offline Cadillac Owners Member
    Automobile(s): 10 CTSV
    Apr 2013
    Jacksonville, FL
    30
    Cut the stock springs all you want. They are linear.
    Do not cut the eibachs progressive springs.
    dqw1's Avatar
    Apr 2005
    Madison, AL
    55
    2,018
    Quote Originally Posted by sunsalem View Post
    I have some noise but I don't plan on cutting the springs.
    DCV
    DCV is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTSV bone stock
    Dec 2012
    Washington DC
    53
    629
    I thought the Eibachs came with sleeves that go on the coils of the spring to stop the squeaking.
    dqw1's Avatar
    Apr 2005
    Madison, AL
    55
    2,018
    No sleeves came with mine. Just need to find a place that can figure this out. Eibach needs to revisit this because almost everyone has had noise until they removed the dust covers and cut the bump stops, the instructions says do not cut the bump stops!
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,729
    Quote Originally Posted by Boosted2000si View Post
    I cut the backs 1/4 on one side, and 1/2 on the other, and it gave it a nice lowered look and I track race it also. I've had zero issues in over two years and they look stock so don't set any visual alarms off either.
    SilverrV is offline Cadillac Owners Member
    Apr 2013
    54
    no dealer would ever cut the stock spring or bump stop imo. they are liable for any damages or problems. better off seeking a suspension shop. I found a truck repair shop that specializes in this.
    dqw1's Avatar
    Apr 2005
    Madison, AL
    55
    2,018
    Quote Originally Posted by SilverrV View Post
    Mine wouldn't even cut the Eibachs or anything else so I think you are correct at least in my situation.
    daowens is offline Cadillac Owners Fanatic
    Automobile(s): 2015i Escalade Premium, 2009 CTS-V
    Aug 2011
    Mt. Vernon, Missouri
    29
    134
    Check out Mighty Mouse on another forum that I can't name. He cut his stock springs and has no issues.
    Jan 2012
    148
    I don't plan to cut the Eibachs, just the stockers.
    Quote Originally Posted by DCV View Post
    Many of the first run of Eibach kits do not have the rubber sleeves. Eibach only found out about the squeaking after getting complaints from customers. They then came out with these rubber sleeves (which are free if you call them). Unfortunately, there is no written instructions on how to install them. I had them "installed" by a suspension shop and it has done nothing to stop the horrible squeaking. Where I live (Oregon) there are apparently, VERY few, if any pro shops who will take the necessary time to get the installation right.
  16. Remove Advertisements
