Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Wheel REMOVAL TROUBLE! HELP!!!
    Khurram11's Avatar
    Khurram11 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS V
    Dec 2012
    Houston, TX
    31
    Hey Guys,
    I need to remove my wheels from my 2011 CTS V to paint the Brakes, BUT I cant take them off cuz my V only came with the Tire INFLATOR KIT and not the Jack and LUG Nuts Wrench. I tried to use my Wife's Lexus Jack and Wrench but the WRENCH didnt FIT the LUG NUTS on my V! (thought all Wrenches were universal Size??) Is there a specific LUG NUT Wrench for our V's?? Any other suggestions are very appreciated!
    Thanks!
    K
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,788
    Re: Wheel REMOVAL TROUBLE! HELP!!!
    Nothing specific. The "X" type has one that will fit which is carried at any auto parts store. It might be either 7/8" or 19MM but not sure cuz....
    staflyr is offline Cadillac Owners Member
    Automobile(s): CTS-V Coupe
    Feb 2013
    31
    What kind of paint are you using to do the brakes?
  5. #4
    Khurram11's Avatar
    Dec 2012
    Houston, TX
    31
    baabootoo : Thanks for the advice.
    Staflyr: I am using the Duplicolor Brake Paint kit.
  6. #5
    Feb 2013
    31
    Thanks.
  7. #6
    RobF300 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V sedan HIS, 2012 CTS4 coupe- Her's
    Jan 2013
    Amityville, New York
    317
    Really?
  8. #7
    baabootoo's Avatar
    May 2010
    Racine, WI
    3,788
    Will you cover the decals or get new ones? I'm going to paint mine but wonder about the heat reaction with stick-on decals.
  9. #8
    Khurram11's Avatar
    Dec 2012
    Houston, TX
    31
    Quote Originally Posted by baabootoo View Post
    I will get new ones. I really like the Decals and the look.
  10. #9
    Mike02z's Avatar
    Mike02z is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V Sedan Black Raven 6 speed manual
    Apr 2011
    50
    404
    Keep in mind the spec for the V lug nuts is 150 ft lbs. Most cars are 90. They will be tough to break free if they in fact were torqued to spec.
  11. #10
    garfin's Avatar
    garfin is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS-V 6MN Thunder Gray; 07 SRX AWD N*;
    Apr 2006
    Roches Point, Ontario, Canada
    1,202
    22 mm.
    Best regards,
    Elie
  12. #11
    Double e's Avatar
    Double e is offline Cadillac Owners Member
    Automobile(s): '11 V WDT sedan, Recaros & Ultraview
    Apr 2012
    27587
    46
    48
    True. I pulled my wheels this weekend & cleaned up the insides... Broke them loose with a torque wrench. Be sure to get a 1/2 inch socket if you use a ratcheting tool. A star (or X) style wrench will probably not give you the torque to break one loose or tighten it to 150lbs.
    22mm is the ideal fit. 7/8 will work but there's some slop and I (you) sure don't want to round off the caps on those lug nuts.
    (I snapped two 3/8 inch ratchet adapters trying to break them loose.)
    Even once lugs were removed, the rear wheels had some rust/corrosion build up and didn't come off the hub easily.
  13. #12
    Lancekl is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V coupe
    Dec 2012
    37
    Wondering why you used a torque wrench to break them loose? Did it just happen to be a longer handle than your normal sockets??
  14. #13
    garfin's Avatar
    Apr 2006
    1,202
    Quote Originally Posted by Lancekl View Post
    When I got the car, I gave up looking for an "X" unit with 4 sockets where 1 of them was a 22 mm socket. So I just bought a 22 mm socket for my torque wrench and I keep everything in the spare tire well.
    Best regards,
    Elie
  15. #14
    Karch's Avatar
    Karch is online now Cadillac Owners Fanatic
    Automobile(s): 2010 TG sedan, 6A,LPE 650, and a few more mods.
    Dec 2009
    Los Angeles
    498
    Quote Originally Posted by Double e View Post
    You used a 3/8" ratchet? I'm not the least bit surprised they snapped.
  16. #15
    cdog533's Avatar
    cdog533 is offline Cadillac Owners Enthusiast
    Apr 2004
    539
    Jam a little paper towel into the end of the socket, otherwise you'll have nice circle gouges at the end of your lug nuts....
    Also, please use a regular floor jack, NOT a Lexus tire-change jack!!!!!
    I think a trip to your local Sears is in order so you can buy a 1/2" Torque wrench, 22mm socket, and floor jack. Oh, and a breaker bar to loosen them.
    150 ft-lbs + 3/8" anything = broken
  • You may not post replies
