Pandora and iPhone 5
Results 1 to 6 of 6
2009-2015 Cadillac CTS-V General Discussion Discussion, Pandora and iPhone 5 in Cadillac CTS-V Series Forum - 2009-2015; S anyone having issues with pandora playing for a minute and then searching only to repeat the process? I tried ...
    SRTVIPER03 is offline Cadillac Owners Fanatic
    Automobile(s): None
    Mar 2011
    Huntington Beach
    132
    S anyone having issues with pandora playing for a minute and then searching only to repeat the process? I tried turning the phone off and restarting but it still happens. This occurs several times per week
    Also my display screen flickers occasionally whether the phone is plugged in or not. The dealer replaced the unit once but it continues.
    Xaqtly's Avatar
    Xaqtly is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 WD Vagon 6MT "Unobtainicorn"
    Jan 2012
    Las Vegas, NV
    1,276
    Re: Pandora and iPhone 5
    Does that pandora issue happen when the phone isn't connected to the car? It seems like that would be a pandora issue specifically, or a general internet connectivity issue as opposed to an audio system connectivity issue.
    Automobile(s): None
    Mar 2011
    Huntington Beach
    132
    I'm using an extension on the oem iPhone cable. I don't think you can play pandora via Bluetooth.
    It doesn't do,it when I use pandora outside of the car.
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,711
    SRTVIPER03, I'm sorry to hear that! If you don't mind sending me the last eight of your VIN, then I'm happy to explore your best next steps. My email is Katie_Lucille@gmexpert.com. Have you already been in touch with our special Infotainment team?
    Best,
    Katie
    Xaqtly's Avatar
    Jan 2012
    Las Vegas, NV
    1,276
    Are you using the Cadillac-supplied iPhone cable to connect to both the USB and 3.5mm audio port inside the center console, and then attaching the Lightning adapter to the 30-pin side? That's what I'm doing and it works. Aftermarket 30-pin cables don't seem to work as well as the OEM Cadillac cable, I was wondering if that might be a factor. Also have you loaded music on your phone and tried to play that, instead of Pandora? If so, did it work normally, or did it have the same issue you're having with Pandora?
    Automobile(s): None
    Mar 2011
    Huntington Beach
    132
    Xaqtly...yes I am using the Cadillac Cable in both aux and usb and then an extension on the 30 pin plugand then the lightening adaptor (from Apple). It worked fine with my iphone 3gs but Im having problems with the 5. Sometimes it works fine and then sometimes the repeated search process. Then I have to disconnect, turn off the phone and restart. I then also have to re-establish bluetooth contact with the car to use the phone. I agree that it is probably the extension cable but just thought I would see if anyone has a fix.
    Thanks for the offer Katie....Ill let you know if we can't fix it.
    I also have to get the V back for the flickering display screen.
  9. Remove Advertisements
