Winter Tires-I am confused 2012 CTSv Coupe - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Like Tree1Likes
2009-2015 Cadillac CTS-V General Discussion Discussion, Winter Tires-I am confused 2012 CTSv Coupe in Cadillac CTS-V Series Forum - 2009-2015; I just installed 4 x Pirelli Sotto zero 255/40/19 snows on my 2010 CTS-V Sedan - except I bought a ...
  1. #16
    dave_brown@shaw.ca is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Dec 2012
    1
    Re: Winter Tires-I am confused 2012 CTSv Coupe
    I just installed 4 x Pirelli Sotto zero 255/40/19 snows on my 2010 CTS-V Sedan - except I bought a second set of four 19" x 9" wide factory wheels to mount them on. I think the factory fronts are 9" wide for the 255 tires and the rears I believe are 9 1/2" wide for the 285's. I would bet that the 255's will fit on the rear 9 1/2" wheels but why not consider a second set of 9" wheels and then you are matching the tires/rims as they are supposed to be matched and then you also dont have to change rubber twice per year. Also, everyone I have spoken to recommends that thinner (i.e. 255 vs 285 in this case) is probably better as snow tires anyway. The only issue I had was that I had to install wheel spacers to clear the Brembo calipers, 2 spacers (approx. 1/8" ea) on each of fronts, 1 on each of the rears, $5 each at CDN tire. According to the Dealer, these wheels were supposed to fit the V but must be for a non V. Car drives great.
    DB
  2. #17
    garfin's Avatar
    garfin is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS-V 6MN Thunder Gray; 07 SRX AWD N*;
    Apr 2006
    Roches Point, Ontario, Canada
    1,201
    Quote Originally Posted by dave_brown@shaw.ca View Post
    DB
    I have the Sottos in the stock staggered sizes mounted on a 2nd set of factory 19" wheels (on our sedans, they are 19 X 9 all round - only the V coupes have larger 9.5" rears) and I do not need spacers. If your wheels look like CTS-V wheels, my guess is that you have the 19" wheels from the Pontiac G8 GXP, which look virtually identical to the CTS-V wheels, but are 19 X 8. The GXP came with 245/40/19 all round, but fitting a 285 on those 8" wheels might not work.
    BTW, where in Canada are you located?
    Best regards,
    Elie
  3. #18
    flatrockguy's Avatar
    flatrockguy is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Raven V Sedan, M6, Graphite Rims, Yellow Brembos Sold
    Jan 2012
    Metro Detroit
    47
    342
    Our sedans actually have 9.5" rims in the rear. With my 255/40/19 Blizzaks on all four corners you can definatly tell the rear rims are wider.
  5. #19
    garfin's Avatar
    Apr 2006
    1,201
    Quote Originally Posted by flatrockguy View Post
    Thank you for catching that, flatrockguy! I stand corrected on the different widths between the fronts (9.0) and the rears (9.5) on the sedans and Vagons. Am I then correct in thinking that the coupe's rears are in fact, 10" wide?
    Best regards,
    Elie
  6. #20
    brian-nicola is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V Coupe Blk Diamond Edition
    Feb 2012
    Nanaimo,Brtish Columbia
    107
    Correct coupes are 9 up front and 10 in the back
  7. Remove Advertisements
