Has anybody installed a "Curb Alert" on a V?
Results 1 to 8 of 8
2009-2015 Cadillac CTS-V General Discussion Discussion, Has anybody installed a "Curb Alert" on a V? in Cadillac CTS-V Series Forum - 2009-2015; How'd you get thru the firewall?...
    itsaz is offline Cadillac Owners Member
    Automobile(s): none yet
    Oct 2012
    Wichita Falls, TX
    11
    SoCalCTSV's Avatar
    SoCalCTSV is offline Cadillac Owners Enthusiast
    Automobile(s): 2012 CTSV Coupe, 1966 Chevelle
    Aug 2011
    Agoura Hills
    50
    696
    Quote Originally Posted by itsaz
    I went around the door but mounted the box in the engine compartment on the shock tower behind the fuse box.
    Oct 2012
    Wichita Falls, TX
    11
    Re: Has anybody installed a "Curb Alert" on a V?
    Quote Originally Posted by SoCalCTSV View Post
    Just had to run the speaker wire? Would you mind posting a pic of the routing around the door? Did you tap into the underhood fuse box?
    SoCalCTSV's Avatar
    Aug 2011
    Agoura Hills
    50
    696
    Tapped into fuse and ran only speaker wire to passenger side door. You can't see it at all. I will take pics later.
    A better question is where are you gonna mount the sensor? Mine keeps getting clipped off as I put it under the very front part of the front lower facia. I disconnected it pending finding a better location. On the grill is a deal killer. I may put it just under the lip of the front license plate as I use a tow hook mount.
    Oct 2012
    Wichita Falls, TX
    11
    I was thinking of putting the sensor 6 or 8 inches further back under the front lip. Don't know if this would hinder it's view of obstacles. I asked the supplier if mounting it behind the grill would work and he just wasn't sure. He did say it needed a clear, unobstructed view.
    BTW, I refuse to mount a front plate. It requires drilling the front facia. NFW!
    SoCalCTSV's Avatar
    Aug 2011
    Agoura Hills
    50
    696
    I have a tow hook mount for the front plate. Use the search function.
    Good idea on mounting it further back.
    mj1980's Avatar
    mj1980 is offline Cadillac Owners Member
    Automobile(s): 2013 Cadillac CTS V Sedan 6A
    Aug 2012
    Houston
    37
    26
    What brand and model are you guys using for the Curb Alert? Just curious how are you integrating it with the V? or is it a stand alone system? Thank you.
    SoCalCTSV's Avatar
    Aug 2011
    Agoura Hills
    50
    696
    Quote Originally Posted by mj1980 View Post
    http://www.curb-alert.com/index.php
    There is no good way to mount the sensor. Under the front of the car is useless unless you never have to drive up an incline. Even mild ones will tear it off. In front of the grill is awful.
    I resorted to mounting it on my front plate which is mounted to the tow hook. Angled it so it is pointed parallel. It works well and not noticeable.
  11. Remove Advertisements
