recommendation for brake bleeder kit
Results 1 to 12 of 12
Like Tree1Likes
  • 2 Post By M5eater
2009-2015 Cadillac CTS-V General Discussion Discussion, recommendation for brake bleeder kit in Cadillac CTS-V Series Forum - 2009-2015; I just learned that there is another driving school this year at mid-Ohio. It is November 3, 4 and 5. ...
    Trionalaw is offline Cadillac Owners Fanatic
    Automobile(s): none
    Dec 2011
    64
    249
    I just learned that there is another driving school this year at mid-Ohio. It is November 3, 4 and 5. Friday, the 3rd, is for instructors and advanced drivers which of course will not include me.
    As I have alerted the forum in the past, my 11-year-old daughter and I installed an air raid intake system to my 2012 CTS- V coupe, which she is now taking full credit for. I need to change my brake fluid to .4 just in case. I have had no problems with my brakes at the past three driving schools I have attended but one never knows!
    I need a recommendation for a good brake bleeder kit that Lily and I can use to change the brake fluid kit.The Mityvac systems have been getting horrible reviews. I know one can get a $10 kit at local automotive stores which use pumping the brake pedal for the pressure. I have read on the forum that is not a very good way to do it.
    Any recommendations? I would like something reasonably priced.
    This Craftsman looks pretty good: http://www.youtube.com/watch?v=JAwQ9kwMdVk
    As always, much appreciated for your help.
    Jim
    Houdini's Avatar
    Houdini is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 CTS-V, 2010 CTS-V 6MT (Sold), 2007 CTS-V (Sold)
    Nov 2007
    St. Louis Metro
    1,405
    Re: recommendation for brake bleeder kit
    I had awesome luck with the motive power bleeder system. It worked great on my V1 and I'm sure it would work the same on my V2 but I haven't tried it. On the V1 I had adapter caps for the brake reservoir and the clutch reservoir. Very easy to use and makes it a one man job.
    http://www.cadillacforums.com/forums...ake-fluid.html
    Automobile(s): none
    Dec 2011
    64
    249
    Thank you, Harry!
    Unfortunately I do not have an air compressor.
    69mets's Avatar
    69mets is offline Cadillac Owners Member
    Automobile(s): 2012 Cadillac CTS-V, MN6, Driven Daily
    Feb 2008
    Colorado
    45
    No need for an air compressor, it pumps up by hand. I too have the motive power bleeder and it works great. Very easy to use.
    Houdini's Avatar
    Nov 2007
    St. Louis Metro
    1,405
    Yep...hand pump for the win.... not that I do a lot of hand pumping.
    JFJr's Avatar
    JFJr is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V (TR-6060, Black Raven/Ebony, Recaros, Ultraview)
    Jan 2009
    Jacksonville, FL
    73
    1,643
    Quote Originally Posted by Houdini
    Too much hand pumping can be bad! Sometimes pressure can be controlled in other ways.
    Jud
    pajeff10 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS4
    Oct 2012
    Mansfield, PA
    49
    194
    I use my MityVac all the time to bleed brakes and to flush out the old brake fluid on our cars. Never had an issue with it. Just have to be sure that you do not suck the reservoir dry during the process. Start at the right rear caliper and then work your way closer to the master cylinder.
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    motive , motive, motive.
    There is no substitute, there is no superior. It's reasonably priced, and it will last--- mine needed new tubing after 4-5 years, but it still works 100%.
    Houdini and Houdini like this.
    cruiser68 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS-V A6 Sedan Modded :)
    May 2011
    Chicagoland
    711
    Quote Originally Posted by M5eater View Post
    +1, had one going on 10 years.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    The one I bought from Griots is awesome. Yes, you need an air compressor, but it is incredibly easy and fast. I've done it multiple times on my V right before track days...
    pmsteinm is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V (Blue Diamond Manual/Recaros/Nav/Suede/Polished)
    Jul 2004
    Raleigh, NC
    291
    +1 for the Motive bleeder. Use the car specific adapters, not the generic one. I have the GM one and the BMW one. I've flushed the V, BMW and even my 2001 Oldsmobile Aurora with it. The only thing it won't do is flush the V's clutch. The clutch appears to not be setup to allow for flushing without taking things apart? Even though the service manual say to do flush the clutch it doesn't actually list a procedure. Flushing the BMW clutch is easy because it has a bleed screw and shares the brake fluid reservoir (that's about the only thing that is easier on the BMW than the V).
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by pmsteinm View Post
    lol wut?
    there's no bleeder screw to flush clutch fluid in the V?
  15. Remove Advertisements
