Eibach Spring Install tomorrow quick Q
Results 1 to 7 of 7
2009-2015 Cadillac CTS-V General Discussion Discussion, Eibach Spring Install tomorrow quick Q in Cadillac CTS-V Series Forum - 2009-2015; I'm getting my Eibach installed on my '12 V-Coupe tomorrow. Did a ton of searching around and reading and found ...
    Bubba Ho-Tep is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V Coupe
    Sep 2012
    South Jersey
    46
    I'm getting my Eibach installed on my '12 V-Coupe tomorrow. Did a ton of searching around and reading and found some people experience squeaking after the install which can be remedied by NOT re-installing the dust caps and cutting the bump stops. Is this for the front, rear, or both?
    Also I couldn't find any posts or mentions about anything needing to be done about the Mag Ride- do you just install the springs as you would on a normal car w/o mag ride? In other words nothing special needing to be done in that respect? Thanks in advance!
    larry arizona is offline Cadillac Owners Connoisseur
    Automobile(s): 10 V 4DR,6M,Blk,2.55,airaid,160t,W4M HX & tune Eibachs
    Feb 2012
    Metro Detroit
    45
    1,347
    Re: Eibach Spring Install tomorrow quick Q
    remove dust caps and trim bumpstop on fronts only, no need to modify magnetic ride rods.
    Stillborn's Avatar
    Stillborn is offline Cadillac Owners Enthusiast
    Automobile(s): 09 DW 4DR,AT,Recaros,metco 2.4,RX c-can,AEM-A/F, 634hp,642tq
    May 2011
    tri-state
    48
    776
    do make sure that said mrc rods are in tact properly (fronts only) after install is complete. if you get a dic reading you'll know why.
    btw, you'll want to do the 5" cut off the fronts for a slight rake. otherwise it will be flush and look alittle awkward. personal preference
    but should be addressed before the install.
    DRL650's Avatar
    DRL650 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS V Coupe
    Jul 2012
    Cape Coral Fl.
    199
    What are you useing for a jack? And where are you jacking from? Thanks.
    Feb 2012
    Metro Detroit
    45
    1,347
    +1 on a 5 inch coil cut on top of front springs!!!!!!
    Sep 2012
    South Jersey
    46
    [/COLOR]
    Quote Originally Posted by Stillborn View Post
    I'm assuming my installer will know what to look for. They are a high end performance shop but specialize in BMWs. I had all of my 335xi work done there.
    Regarding cutting the front springs- I see that is hugely popular. If not and it's "flush" what does that mean- same height in front and back?
    Feb 2012
    Metro Detroit
    45
    1,347
    if you dont cut the front springs you will have the dreaded "droopy ass" effect. Rear will sit slightly lower than the front. Cut 5" off the top coil of the fronts and its PERFECT.
    Also unless your shop is familiar with the V they will not know what the magnetic ride suspension is all about. Just pop one end of the rod off and make sure you sanp them back on. Very easy. If you drop the a arm without unhooking the MR rods it could yank on the MR solenoids.
  10. Remove Advertisements
