Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: Replacing brake pads
    thunder gray is offline Cadillac Owners Member
    Automobile(s): 09 CTS-V
    May 2009
    Sacramento, CA area
    93
    If you were replacing your brake pads which brand and type would you chose?
    RapidRob's Avatar
    RapidRob is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V Black/Black, manual
    Dec 2008
    Seattle area
    1,347
    Re: Replacing brake pads
    ^^^ - I've got a set of Hawk Ceramics waiting for when my oem pads wear out. Trying to reduce the dust a little, although I hear that the ceramics may not stop as well - we'll see ... ?
    Rob
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    May 2011
    Central Florida
    2,840
    I'm using these and love them so far. Bear in mind I don't track or drive the piss out of it. Less dust than stock and damn near as much bite. Good alternative for me and my driving style.
    Posi Quiet semi-metallic brake pads - rear (D1053)
    Posi Quiet semi-metallic brake pads - front (D1405)
  5. #4
    neuronbob's Avatar
    neuronbob is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 6MT V wagon, OBM, 2009 silver V sedan (traded)
    Dec 2007
    Cleveland area, OH
    48
    4,526
    I like the stock feel and I don't race my car, so....stock for me even with the dust. I just use a dust repellent on the wheels.
  6. #5
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by RapidRob View Post
    Rob
    I have the Hawks Ceramics. I honestly can't tell a difference between them and the Cmax pads I had on the black car. Maybe Pedal feel is a tiny bit better, but it still brakes worse, they have a wooden feel and I wouldn't use them in an HPDE or to try to stop the car from near VMAX. * actually* the Hawks have a metal shim the Cmax pads didnt. The shim has anti-sequel grease backing which causes the shim to float around the pad and I have to prop it up every so often so it's not hitting the rotor.
    Not sure if I prever the occasional noise from the Cmax over having to adjust the shim every month.
    Was it worth the extra $$$? Not so far, if you want a low-dusting pad, save yourself $200, just pickup any of the knock-offs and don't go crazy trying to stop from 150+MPH.
  7. #6
    4DoorV is offline Cadillac Owners Member
    Aug 2009
    83
    Also using Cmax. Good feel, very similar to stock once they get some wear, and very low dust. absolutely no noise, i did put some brake quiet on shims.
  8. #7
    jzchen is offline Cadillac Owners Fanatic
    Automobile(s): '85 Sedan de Ville, '10 CTS-V
    Sep 2009
    Arcadia, CA
    41
    409
    Duralast Gold Cmax has a $10 rebate going on right now. So that's $64.99 on pads you can get replaced free for the rest of your life as long as you don't wear them down to the plate.
  9. #8
    r1concepts's Avatar
    r1concepts is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Dec 2006
    Cerritos, CA
    256
    Hawks or Stoptech pads if you tend to drive a bit more aggressive. Or go with Posi Quiet Ceramics if your an "average" drive since you do get low dust and low noise but not much stopping power compared to the Stoptechs or Hawks.
  10. #9
    jessrayo is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Coupe
    Apr 2012
    Ardmore, OK
    94
    I'm on the 3rd set of pads but run my car on the track. If you don't track it, get the ceramic pads. If you plan on running it on track days you need some upgrades beyond the pads. I see you are in California and you probably could run in some of the Cadillac events. Warning, track driving is highly addictive...
  11. #10
    boplaw's Avatar
    boplaw is offline Cadillac Owners Member
    Automobile(s): 11 CTS-V Coupe
    Nov 2009
    51
    Quote Originally Posted by r1concepts
    Has Stoptech started making the fronts? I could only find rears a few months ago. Installed the Hawks before I tracked the OEMs, but I did not like the Hawks on the track so I will either try Stoptechs or put my OEMs back on.
  12. #11
    RapidRob's Avatar
    Dec 2008
    Seattle area
    1,347
    Quote Originally Posted by M5eater View Post
    Quote Originally Posted by boplaw View Post
    Hmmmm - I may have to rethink installing the Hawks. oem pads do work good and the dust repellant also works good, soooo ....
    Rob
  13. #12
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,777
    Duralast also, except for the track. I love them and they stop just fine in the city and in the winter. M5, I just ground those corners on the shim down a tad so they wouldn't rub.
  14. #13
    6104696 is offline Cadillac Owners Connoisseur
    2,178
    Way back when, Dreamin' had prepared a nice step-by-step tutorial for replacing brake pads on the V1 brakes; this is still part of the 2004-2007 FAQ. Basically popping out the pins, compressing the calipers, and popping in the new pads. Is it basically the same process for the bigger V2 brakes? Anything special that one needs to know or to buy (besides good pads)?
  15. #14
    CVP33's Avatar
    CVP33 is offline Cadillac Owners Master
    Automobile(s): '04V, '05V, '06SRT8, '10V, '13ZL1, '12 V, '16 Z06 SC757
    Feb 2004
    Killer of diffs 7X
    51
    6,441
    Quote Originally Posted by 6104696 View Post
    I would like to know as well. I did 10 sets of pads and 6 sets of rotors on my SRT8. Easiest brakes I've ever done. Hoping the V's are similar.
  16. #15
    larry arizona is online now Cadillac Owners Connoisseur
    Automobile(s): 10 V 4DR,6M,Blk,2.55,airaid,160t,W4M HX & tune Eibachs
    Feb 2012
    Metro Detroit
    45
    1,347
    Pretty sure you push out (tap out with awl and hammer) two pins, remove pad clip and the pads come out the top of the caliper, use your hands to manually push in all the pistons and slip in new pads put clip back in and tap in two pins. Viola Done (probably should bleed calipers) Pretty sure the order is readily available on line. Right rear, right front, left rear left front (not sure on inner or outer bleeder order)
  • You may not post replies
