Gut feeling is there is something wrong (or at least not running right)... - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Like Tree5Likes
2009-2015 Cadillac CTS-V General Discussion Discussion, Gut feeling is there is something wrong (or at least not running right)... in Cadillac CTS-V Series Forum - 2009-2015; I picked the car back up today from the dealership. The SC was replaced and in them doing it as ...
  1. #31
    AfAdam is offline Cadillac Owners Member
    Automobile(s): 2010 CTS-V Sedan
    Nov 2011
    Colorado Springs, CO
    36
    14
    Re: Gut feeling is there is something wrong (or at least not running right)...
    I picked the car back up today from the dealership. The SC was replaced and in them doing it as a whole unit the valve/actuator were also replaced. They also replaced the SC belt. The tech said he did notice the SC was making noise before the repair. After the repair they test drove my car with a computer and then compared it to a new one off the showroom floor (could tell they drove it because it had bug splats on it and the tires were dirty). They said it was nearly the same based on the readings taken. So my thoughts driving it home... It is now making 7-8psi (more where I thought it should be); about 2-3 psi higher than before. It also seems to register on the boost gauge earlier when I go about 40% throttle. I also spun the wheels without meaning to in touring mode at an intersection. Then close to home I re-tried the launch with TC disabled in sport mode and the wheels spun all the way through first gear. So judging by the non-calibrated "seat of my pants", it definitely feels better. Next step, another dyno run and another run with another stock V to compare.
    On a side note, my friend following me after leaving the dealership noticed a little smoke from the tailpipes when I got on it. I figure that may be due to the new part and some contaminants being burnt off. I assume that will disappear pretty quickly, but should that be an issue or will it go away in the near future?
  2. #32
    TriTexan is offline Cadillac Owners Fanatic
    Automobile(s): Automobile?? Lake! Big Lake!!
    Apr 2012
    North Houston Area
    186
    AfAdam - excellent work sticking to your approach of measuring things carefully. That's the ONLY way to know if the car is performing correctly and the repairs have had the right effect. Keep us posted!
  3. #33
    DiamondWhtV is offline Cadillac Owners Fanatic
    Feb 2010
    66
    364
    Good news indeed. Let us know the final dyno results.
  5. #34
    js615 is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS-V (previously '05 CTS-V), '11 SRX
    Sep 2006
    Olathe, KS
    48
    331
    This thread is a warm fuzzy for why this forum needs to exist. Well done gang!
  6. #35
    Pphilthy's Avatar
    Pphilthy is offline Cadillac Owners Fanatic
    Apr 2012
    Howell, NJ
    43
    185
    Quote Originally Posted by AfAdam View Post
    Given that they already test drove your car, I would assume that any 'contaminants' would have already been burnt off...? The important thing to note is, what color is the smoke...? Did you get the results from the compression and leak down test...? These are the two most informative tests you can do to gauge the health of your motor...
  7. #36
    Nov 2011
    36
    14
    I finally got some free time to take it back to the dyno since getting the SC replaced. Apparently it did some good. Went from 369HP to 402HP. Definitely feels a bit better, but still want to get a compression/leak down test and new plugs in. Probably won't be able to get it in for this for a couple weeks. Also watched pretty closely to the exhaust during the runs and didn't notice any kind of smoke. At least its moving in the right direction...
  8. #37
    TTuned is offline Cadillac Owners Fanatic
    Automobile(s): 09 Cts-V650
    Jan 2012
    34
    129
    My car felt slow when i got it too didn't really spin tires and things like that. Dyno proved 440whp, and it was ugly. Paid a shop for a tune they data logged, and found things way off. and dyno tuned resulted in 520/520whp so =80/80 on 91 oct. I have mods but i know how u felt.
    Our theory was that a dealer somewhere along the way messed with the software when the car had a tune. Probably changed some things to stock like settings while leaving others, aka didn't know what they were doing, or did some kind of a dealer sw update without telling the owner.
  9. #38
    Nov 2011
    36
    14
    Quote Originally Posted by TTuned View Post
    Thanks for the input. I think my next step is definately a compression/leak down test (and new plugs while I'm there). If everything checks out there, I'll move on to the ECU for tuning like you mentioned. Does anyone know off the top what the cylinder compression is supposed to be. Also any recommended spark plug or stick to manufacture recommended...
  10. #39
    Kadonny's Avatar
    Kadonny is offline Cadillac Owners Connoisseur
    Automobile(s): Owned 3 V's, now driving a GC STR8
    Dec 2004
    Pennsylvania
    53
    2,573
    402 still seems low to me, even at your elevation. At 15% loss of stock numbers. that still has you in the 480 range. Lessen it for elevation and you should still be showing 440 at least I would think. I'm not the expert, so maybe others will chime in.
    Regarding the plugs, lots of people have used with good results the NGK TR6 plugs. When I had my car, I used these plugs and had good success with them, I know many of the performance guys use them.
    Good luck with your car, I still think you should be putting down more power so keep checking on things.
  11. Remove Advertisements
