Bump...
Results 1 to 12 of 12
2009-2015 Cadillac CTS-V General Discussion Discussion, Bump... in Cadillac CTS-V Series Forum - 2009-2015; When I go over a bump, my V feels like it has something loose like the wheel is about to ...
    killer67 is offline Cadillac Owners Fanatic
    Automobile(s): '10 CTS-V, '09 Escalade
    Feb 2010
    Florida
    168
    Bump...
    When I go over a bump, my V feels like it has something loose like the wheel is about to fall off. Wheels are 150 ft-lbs so it is not that and correct PSI. I wonder if it is the steering, hubs, struts, or the D3 sway bars. I hear it when I go over any bumps, manhole cover, pothole, driveway, turning - it just feels like something is going to get loose at any moment. Any ideas?? Sorry for the vague, non-mechanical symptoms. Thanks in advance for any help.
    elphil is offline Cadillac Owners Connoisseur
    Automobile(s): Really Cool '11 CTS-V Wagon
    Oct 2009
    Goodyear, AZ
    78
    1,072
    Re: Bump...
    I believe the torque spec' for the wheels is about 150 ft-lbs. Someone correct me if I'm wrong on that.
    Xaqtly's Avatar
    Xaqtly is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 WD Vagon 6MT "Unobtainicorn"
    Jan 2012
    Las Vegas, NV
    1,276
    Re: Bump...
    I keep seeing that it's supposed to be 158 ft-lbs.
    Oct 2009
    Goodyear, AZ
    78
    1,072
    Re: Bump...
    OK - 2011 CTS-V Manual page 12-3, Vehicle Data, shows wheel lug torque at 140 ft-lbs.
    cruiser68 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS-V A6 Sedan Modded :)
    May 2011
    Chicagoland
    711
    Re: Bump...
    I thought the tsb for wheel clicking upped it to 158ft-lbs
    RapidRob's Avatar
    RapidRob is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V Black/Black, manual
    Dec 2008
    Seattle area
    1,343
    Re: Bump...
    Rob
    commander112's Avatar
    commander112 is offline Cadillac Owners Enthusiast
    Automobile(s): '08 STS-V Sedan Black Formerly three CTS-V's, XLR and STS4N*
    Oct 2005
    Waterford, MI
    846
    Re: Bump...
    I doubt it has anything to do with the wheel torque. I would suggest starting at the aftermarket work done on the front end. If not done properly and to proper spec things can get loose. This can be a real safety issue and should be looked at sooner than later. Don't just get under there and start shaking things by hand. The forces at work here are much stronger than you are.
    tedcmiller is offline Cadillac Owners Connoisseur
    Apr 2004
    1,827
    Re: Bump...
    I'm with commander112. The problem is probably not wheel torque.
    By the way, the manual will say 140 while the TSB says 158. In either case, the number of lb-ft specified is a lot more than 105.
    Oct 2009
    Goodyear, AZ
    78
    1,072
    Re: Bump...
    I, also, agree with commander112. Aftermarket changes are the first suspects.
    Feb 2010
    Florida
    168
    Re: Bump...
    I edited the post to reflect my 150 ft-lbs which was a typo. I will look for torque specs on sway bars and struts
    baabootoo's Avatar
    baabootoo is online now Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,735
    Re: Bump...
    Some cars had those lock nuts loosen on the control arms, so make sure those haven't moved.
    Feb 2010
    Florida
    168
    Re: Bump...
    I was thinking that might be my first place to look.....thanks baabs
  15. Remove Advertisements
