Octane Question - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Like Tree7Likes
2009-2015 Cadillac CTS-V General Discussion Discussion, Octane Question in Cadillac CTS-V Series Forum - 2009-2015; lol - you are wrong on so many fronts... I got a Pepsi challenge for you, take your car to ...
  1. #16
    Pphilthy's Avatar
    Pphilthy is offline Cadillac Owners Fanatic
    Apr 2012
    Howell, NJ
    43
    185
    lol - you are wrong on so many fronts... I got a Pepsi challenge for you, take your car to a dyno and do three consecutive pulls on 91 octane, and then fill up with 100 octane and do three more consecutive pulls - you'll be back here eating your words for a the reasons I've already posted...
    The slower more controlled burn of the higher octane fuel will allow the ECU to provide access to the full timing tables and control heat, knock and pre-ignition far better than 91 octane... The 91 octane runs will lose power at a much higher rate as the ECU pulls timing...
    You also DiD say the you can turn 87 octane fuel into 110 by just adding water HAHA! Now you're not going to man up and admit yore wrong...? Water injection which was pioneered back in the old turbo charged F1 days was used to reduce temps, not increase compression or octane... lol
    I'm sorry, but you are just making me laugh now...
  2. #17
    GMX322V S/C's Avatar
    GMX322V S/C is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V, 2009 535i
    Dec 2008
    SoCal
    1,840
    Different rating systems (DIN vs. SAE HP and RON only vs. R+M/2 octane rating). This has been discussed before in these forums. There is no difference in output using the same rating systems.
    Quote Originally Posted by Tampa2Dubai View Post
    FYI .. european/export spec cts-v's are rated at 564bhp, due to running on 95-98 octane
    http://www.cadillaceurope.com/en/index.php#/cts-v-sedan
  3. #18
    Kluch is offline Cadillac Owners Fanatic
    Automobile(s): '13 V
    Apr 2008
    379
    Re: Octane Question
    Ahhhh! Which fuel nerd do I believe?
  5. #19
    Pphilthy's Avatar
    Apr 2012
    Howell, NJ
    43
    185
    Kluch, I don't know his tuning experience or how many boosted cars he has built, but he isn't making much sense...
    Meth injection will increase the octane, NOT water lol. That comment in it of itself is enough to ignore anything he posts haha
  6. #20
    V locity's Avatar
    V locity is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V A6, 752 RWHP Stock airbox & stock exst
    Jan 2012
    Katy, TX
    1,110
    Re: Octane Question
    Quote Originally Posted by Pphilthy View Post
    I would agree that there is a small amount of wiggle room in the, read this (factory programmed ECU timing), that could create a nominal amount of HP change from a "slightly higher" octane rating under certain circumstances. But, If you think you're going to see "real" power increases in proportion to octane rating increases, I'll throw the "Pepsi Challenge" back @ ya. Let's make it more interesting too. Assuming you own a V2??? (and your V is still 100% stock) go find some BP, "VP110" (the highest rated unleaded out there) & drive it around for a few tank fulls. If your emmission system is still alive, go to the dyno & post it up for us. According to your logic... ~20% higher octane will equal an extra, say 100 hp. I won't be putting that stuff in my car till it's built & tuned for it!
    Fireverm's post on water injection & octane is correct too:
    http://en.wikipedia.org/wiki/Water_injection_(engines)
  7. #21
    FLTRI's Avatar
    FLTRI is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 V-Wagon & 2012 SRX Premium
    Jul 2011
    Las Vegas, NV
    52
    1,004
    Re: Octane Question
    You should probably stop now, you're just embarrassing yourself at this point.
    Just saying'...
  8. #22
    Fireverm is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V Sedan Black Diamond manual
    May 2011
    Las Vegas
    208
    Re: Octane Question
    Man, this guy is something else, lol.
    He's right. I just can't believe it, but I am so wrong and he has rightfully called me out like the intellectual fraud that I am. But at least on the bright side, with all of this new found knowledge.... I don't need my V anymore for spirited driving. I'll just start running my bone stock 2012 Chevy Cruze Eco with it's turbocharged 1.4L inline 4 on straight octane booster and I'll never miss the V's power again. I figure since it can run 86 octane and it's even newer than my 2011 V, it's ecu shouldn't have a problem to bring up the stock 138hp to over 500. Just think how much octane booster and Cam2 110 octane you can buy if you just bought this sweet baby for 18k instead of 65k for the V....amIright?
  9. #23
    Pphilthy's Avatar
    Apr 2012
    Howell, NJ
    43
    185
    Listen - I have a great amount of knowledge and if you guys know it all, then I really will just stop now and wish you the best of luck...
    My posts were correcting blatant wrong statements made here - injecting water turns 87 octane into 110 octane, and running 100 octane will make less power than 91 octane on a forced induction car, etc... I provided a detailed explanation on why that is the case and you guys are just trying to take my posts out of context now... I never said you will gain huge power, that's you little boys stirring the pot - I said you would NOT lose power and would actually make more than 91 octane!
    Water injection by itself isn't going to give you any gains - it will act as a cooling agent and knock suppression at best - METH injection will provide more power by increasing the octane rating and doing a much better job of cooling vs water... With tuning of course... I don't need a google reference, I've been there done that for the past 15 years...
    I know that I'm new to this forum but believe me, I'm not new to high HP forced induction cars...
  10. #24
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,733
    Re: Octane Question
    So are the Canadian dollars and gallons still the same as ours?
  11. #25
    V locity's Avatar
    Jan 2012
    Katy, TX
    1,110
    Re: Octane Question
    think 3 tanks of VP110!!! Then post your dyno....
  12. Remove Advertisements
