Car on when bleeding brakes ??
Results 1 to 3 of 3
2009-2015 Cadillac CTS-V General Discussion Discussion, Car on when bleeding brakes ?? in Cadillac CTS-V Series Forum - 2009-2015; I searched other threads on brakes, but was unable to get my question anwsered.... When bleeding brakes on the V ...
    bbang is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V Sport Wagon, 2013 Escalade
    Dec 2011
    Southern California
    118
    When bleeding brakes on the V with a power bleeder, does car need to be running to engage theABS ??
    Any help would be great
    cruiser68 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS-V A6 Sedan Modded :)
    May 2011
    Chicagoland
    711
    Re: Car on when bleeding brakes ??
    I bleed with the engine off. It will bleed all fluid except that in the abs pump. No need to flush the pump IMO as there is so little fluid and it will get recirculated when the abs kicks in. If you have cracked open the system (replaced any lines) you should bleed the abs pump. I've done that two ways. The best is hook up to a Tech II and open the pump circuit and bleed. The other way is to do a full bleed, take the car out on a dirt or otherwise slippery road and hit the brakes so the abs goes on. Then bleed again.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Not much to add, I'll just say I've used a power bleeder with car off. Works fine...
