Using Spotify & Pandora in the V - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 35 of 35
Like Tree5Likes
2009-2015 Cadillac CTS-V General Discussion Discussion, Using Spotify & Pandora in the V in Cadillac CTS-V Series Forum - 2009-2015; Thanks for the reply, Xactly. The weird thing is that the failures seems to cluster. What I mean is that ...
  1. #31
    PeteK is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V Wagon, 1972 Eldorado Convertible
    Jan 2011
    Tehachapi, CA
    101
    Re: Using Spotify & Pandora in the V
    Thanks for the reply, Xactly. The weird thing is that the failures seems to cluster. What I mean is that it will go for a while without getting the error, then I'll have a spate where it will do it every minute or so (or less). I'm trying to figure out if I can correlate it to something.
  2. #32
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,711
    Quote Originally Posted by PeteK View Post
    Hello Peter,
    If this is a concern that is still persistent and you would like to work with your dealer, please let me know. I can be contacted via private message and am more than happy to help.
    Sincerely,
    Laura M.
    Cadillac Customer Care
  3. #33
    warmwater is offline Cadillac Owners Member
    Automobile(s): CTS-V Coupe
    Jun 2013
    38
    So whats the deal on this issue controlling Pandora or Other via factory head unit!
    Iphone version?
    IOS version?
    Cables?
    This works or not what versions of the CTS-V?
  5. #34
    Xaqtly's Avatar
    Xaqtly is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 WD Vagon 6MT "Unobtainicorn"
    Jan 2012
    Las Vegas, NV
    1,277
    I haven't tried Pandora, but I use Spotify on a regular basis. The same rules apply as for listening to music that's on your phone, since Spotify and Pandora utilize Apple's APIs for music playback on iOS devices.
    Step 1: Start playing music on the phone, whether it's Pandora or Spotify or music you loaded onto the phone.
    Step 2: Make sure the infotainment system is turned on, then connect the iPhone using the supplied GM cable, if it's an iPhone 5 or 5S you will also need Apple's Lightning adapter. Make sure the GM cable is plugged into BOTH the USB port AND the 1/8" audio jack in the center console.
    Step 3: Profit
    At this point, at least with Spotify, you will be able to adjust volume and skip tracks using the buttons on the steering wheel. I suspect Pandora works the same way, but I haven't tried it myself.
  6. #35
    Jun 2013
    38
    Yep it works just tested it with pandora and iphone 4 ios 7, wow I did not know that this would work I went strait to bluetooth.
    Thanks for the post.
    I still think I am going to mount a Tablet in front of the factory Nav and use split screen and run Pandora / Spotify and Waze at the same time, I will loose the steering wheel controls.
  7. Remove Advertisements
