Putting 2010 V on 4 Jack Stands
Results 1 to 11 of 11
Like Tree1Likes
  • 2 Post By M5eater
2009-2015 Cadillac CTS-V General Discussion Discussion, Putting 2010 V on 4 Jack Stands in Cadillac CTS-V Series Forum - 2009-2015; Ok, I am going to be taking all my tires off my 2010 CTS V to have them powdercoated. I ...
    HuskerHoss is offline Cadillac Owners Member
    Automobile(s): 2010 CTS-V
    Oct 2010
    Nebraska
    10
    Ok, I am going to be taking all my tires off my 2010 CTS V to have them powdercoated. I will be putting my car up on 4 jack stands. I have read all of the threads on jack placement. Here are my questions.
    1. Where is the best place to jack up the back of the car?
    2. If I use the the jacking point on the rear, is there enough room to put a stand right there and the same time?
    3. Is it better to jack up the car right inside the rear suspension on the frame and then place the stand under the jacking point?
    4. I was planning on using the jacking points as a point to put the 4 stands, do you agree?
    5. I was going to lift the front end first on the cross bar and put the front 2 jack stands under, then do the back, thoughts?
    That is all for now, any suggestions would be great. Thank you.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Re: Putting 2010 V on 4 Jack Stands
    Always tricky on my V1. And while I haven't had the V2 suspended on all corners, I'd probably do it the same.
    I would back the V onto rhino ramps. Then I would jack up each rear side on the rear subframe where it bolts to the frame. Stick a stand under each side where the jack pucks go. Then from under the center of the car, I stick a jack under the front of the subframe and lift from there. Then stick a stand at each corner of the subframe.
    Damn, I would love a lift...
    Prof's Avatar
    Prof is offline Cadillac Owners Enthusiast
    Nov 2008
    Wadsworth, IL
    826
    Better idea...buy four Pirelli Sottos...put them on four new wheels, then send the old wheels off to be powder coated over the winter...and don't worry about jack stands at all...
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    you could do the subframe in the rear like jim mentioned, and for the front I put mine near the pinch welds(most outboard location with a flat surface before the ''pinch'', it's also fully boxed and thicker steel), jacking up from the front subframe. i would refrain from putting the stands where the pucks go or anywhere on the front subframe. You *will* bend the thin metal where the lift pucks go and the front subframe isn't steel(source: experience), so I wouldn't put them on there either.
    you see where the lift has a hold of this wonderful V2 in the front? Don't Jack (without a puck) or place the stands there.. it *will* bend that area. The area where it has a hold of it in the rear is where I would put the stands.
    thebigjimsho and thebigjimsho like this.
    Oct 2010
    Nebraska
    10
    Thanks for the replies. I am a little confused still, sorry. Where exactly do you mean by the "pinch"? I am looking at the diagram somebody posted of the underneath of the V. Are you talking about putting the stands right where the front subframe meets the frame, but on the frame still? My other question is, if I look at the picture you sent, it looks like the hoist is picking it up by the rear jacking points, so I must be missing something. Please enlighten me more. Thank you again.
    Automobile(s): ZIP
    51,885
    Where the jacking points are will be sturdy enough to lift the car. But if you don't use pucks, you will bend the pinched metal. It's not a big deal but, aesthetically, it will look crappy when it bends.
    Oct 2010
    Nebraska
    10
    I am more concernced about where to put the jack stands and my other questions up above so if anybody has any more suggestions, I would take them. Thank you.
    baabootoo's Avatar
    baabootoo is online now Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,788
    I don't mean to be filp, but why not where the manual says to jack the car? Lift the back at the differential, and find a second spot(s) for lifting the front. Put the jack stands under a 2" x 6" piece then.
    MSOsr's Avatar
    MSOsr is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 Thunder Gray CTS-V coupe and Raven Black 2007 SRX
    May 2007
    Jacksonville, FL
    589
    Is there some place to buy jack plugs for the V2?
    Mike (got V1 pucks from a BMW provider)
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    I saw these in a thread a while ago,
    http://www.cau-llc.com/cgi-bin/webst...rame=&cart_id=
    post it up and I'll circle where.
    Oct 2010
    Nebraska
    10
    Here is the link of the undernearth of the V that I was referencing. Thank you for your help.
    http://www.cadillacforums.com/forums...ing-cts-v.html
  14. Remove Advertisements
